Author Topic: Fixing Crankshaft Threads  (Read 6791 times)
DuckRyder
Re: Fixing Crankshaft Threads
« Reply #15 on: September 26, 2023, 10:39:22 AM »
Coming back to this, anyone know the tread diameter and pitch, looking at options.
The ARP bolt is pretty long already.
Robert
« Reply #16 on: September 26, 2023, 11:57:33 AM »
The crank balancer bolt is 5/8" fine thread, 5/8-18.
« Reply #17 on: September 29, 2023, 03:07:26 PM »
They make helicoil kits, 41/64 drill and a tap for the thread insert. I have never done one on a crank, but should be doable
DuckRyder
« Reply #18 on: September 30, 2023, 02:06:24 PM »
Yup, got it in my cart... longest insert seems to be .98, wondering if i can/should stack inserts... guess .98 is 1.5 times bolt diameter so it theoretically should be plenty.
Bigger issue seems to be that i cant seem to find a 41/64 drill guide or 5/8 tap guide. moderately concerned about getting it straight...
Robert
pbf777
« Reply #19 on: October 01, 2023, 02:25:29 PM »
............wondering if i can/should stack inserts...
      All I could say is good luck with that!   ::)
      Aka...........no, don't try it!   ;)
      Scott.
Tunnelwedge
« Reply #20 on: October 01, 2023, 03:07:52 PM »
      Scott.
He could make a thread insert as long as he needs.
But he would need a lathe to fix it properly.
« Reply #21 on: October 01, 2023, 03:19:19 PM »
I've built some SBFs with Callies cranks that had a stud and nut for the balancer.  Is that an option for you or are all the threads gone?
DuckRyder
« Reply #22 on: October 01, 2023, 04:11:00 PM »
      Scott.
Noted, wont try that.
It might be an option, i will see...
Robert
pbf777
« Reply #23 on: October 01, 2023, 06:10:18 PM »
........ guess .98 is 1.5 times bolt diameter so it theoretically should be plenty.
      Yes, it'll be fine.   ;)
      Just stop and think of what the standard torquing spec. might be on a 5/8 X 18t fastener vs. what you might be actually torquing this fastener to in your instance?   :-\
      Scott.
