Author Topic: Is there an epoxy strong enough to cover a divot in the block deck?  (Read 8948 times)
Re: Is there an epoxy strong enough to cover a divot in the block deck?
« Reply #15 on: April 08, 2023, 07:55:12 AM »
Not sure how far you are from a welder.  I've had a guy fix stuff on an assembled engine when under a serious time constraint.  We covered EVERYTHING up with foil HVAC tape and approached it like a surgeon - just uncovered the spot we were working on.  Ended up working just fine although it sure looked sketchy while doing it.
gkieffer
« Reply #16 on: April 17, 2023, 07:56:25 PM »
TIG weld nickel 99, flat file then blue and scrape like lathe ways are done, then send it.
