Author Topic: Lykins Motorsports 427 MR With Pond Block  (Read 4435 times)
« on: March 28, 2023, 08:38:06 AM »
Still catching up....
Performance Summary:
      Cubic Inches:    429           Dyno brand: Stuska
      Power Adder:   N/A            Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  471 @ 5600
      Peak Torque: 485
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Robert Pond Motorsports, cast iron, 4.250"
   Crankshaft brand, cast or forged, stroke, journal size:  Factory Ford 390
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec forged, flat top
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Federal Mogul
   Piston rings brand, size, other notes:  Total Seal 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  M57HV, Canton front sump pickup
   Oil pan, windage tray, oil filter adapter:  Canton front sump
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller, 233/243 @ .050"
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet timing set, factory timing cover
   Cylinder heads brand, material, port and chamber information:  Factory C5AE-F, non-ported
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI stainless, 11/32", 2.190"
   Exhaust valve brand, head size, stem size:  SI stainless, 11/32", 1.750"
   Valve springs brand, part number, specs:  PAC dual springs
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports, roller tip non-adjustable
   Rocker shafts and stands, brand, material:  POP HD
   Pushrods brand, type, length:  Custom Trend
   Valve covers, brand, type:  Cobra Lemans
   Distributor brand, advance curve information:  Factory FE with steel gear & Pertronix
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Factory cast iron replacement
   Intake manifold brand, material, porting information:  Ford Sidewinder
   Carburetor(s) brand, type:  Holley 800
   Exhaust manifolds or headers brand, type: Dyno headers
Re: Lykins Motorsports 427 MR With Pond Block
« Reply #1 on: March 28, 2023, 04:46:42 PM »
Nice Brent looks great and probably sounds better. Curious how the pond block was as far as the machining, was everything smooth going.
« Last Edit: March 28, 2023, 05:17:41 PM by Stangman »
« Reply #2 on: March 28, 2023, 05:25:16 PM »
I much prefer the Pond blocks.
