Author Topic: Lykins Motorsports 465ci, Trick Flow Heads, Solid Flat Tappet  (Read 3964 times)
Built this one a couple of years ago, never did put it up here.  Nice to see the old flat tappers making some horsepower.
Performance Summary:
      Cubic Inches:   465            Dyno brand:  Stuska
      Power Adder:   N/A            Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  676 @ 7200
      Peak Torque:  595
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  BBM cast iron, 4.310" bore
   Crankshaft brand, cast or forged, stroke, journal size:  RPM, 3.980", 2.200"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.800"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec forged, 12.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:
   Piston rings brand, size, other notes:  1.5/1.5/3mm
   Oil Pump, pickup, and drive:  M57HV, Milodon pickup
   Oil pan, windage tray, oil filter adapter:  Milodon, no tray
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"): Custom Lykins Motorsports solid flat tappet, nitrided
   Lifters brand, type:  Trend tool steel
   Timing chain and timing cover:  Ford Racing timing set, factory timing cover
   Cylinder heads brand, material, port and chamber information:  Out of the box Trick Flow
  Intake valve brand, head size, stem size:  2.190", 11/32"
   Exhaust valve brand, head size, stem size:  1.625", 11/32"
   Valve springs brand, part number, specs:  Manley Nextek
   Retainers and locks brand, part number, specs:  Manley titanium
   Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D street, 1.76
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Custom Trend
   Valve covers, brand, type:  FE Power
   Distributor brand, advance curve information:  MSD
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  CVR electric, FE Power water pump adapters
   Intake manifold brand, material, porting information:  BBM Tunnel Wedge
   Carburetor(s) brand, type:  Quick Fuel 750 x 2
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: March 28, 2023, 05:46:22 PM by blykins »
Re: Lykins Motorsports 465ci, Trick Flow Heads, Solid Flat Tappet
« Reply #1 on: March 28, 2023, 05:15:16 PM »
I don’t know it just seems to me that 452-465 ci alway makes good power. Whether it’s a good stroke to bore or what but it just to have good results.
« Reply #2 on: March 28, 2023, 05:23:59 PM »
Yep, it seems that way to me too.  My Tunnel Ports do really well with that bore/stroke combination.  In the SBF world, it's a 427-434 that makes a ton of power for what it is.
