Author Topic: Need 1962 406 3x2 Holley carb kits info  (Read 3861 times)
winr1
« on: September 27, 2022, 12:33:11 AM »
A Friend dropped off his 3 carbs for me to soak, wanted to rebuild them himself so I did not write down numbers
Hey PMd me the 3 kits he bought from autozone did not work, said the carbs were 2436s ...will find out tomorrow if they are all the same
The middle has a choke and power valve, the front and back jet plate are blank and not drilled for power valves
All 3 jet plates have idle screws
My info shows the end carbs should be 2437s ...
Whatever I find, I could use info on what gaskets to use and who I may purchase from please
Will update tomorrow
Ricky.
1964Fastback
Re: Need 1962 406 3x2 Holley carb kits info
« Reply #1 on: September 27, 2022, 06:31:39 AM »
Holley 3-888 kit worked for me.  I have a 3208 center carb, which I believe was a service replacement, and 2437 end carbs.  They are as you describe - power valve in the center carb only, 6 idle mixture screws.
Pat
shady
« Reply #2 on: September 27, 2022, 08:23:33 AM »
I use 3 standard motor kits # 1570. About $20. a piece from rock auto.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
winr1
« Reply #3 on: September 27, 2022, 11:12:15 AM »
Many thanks guys !!
Ricky.
StarlinerRon
« Reply #4 on: October 01, 2022, 07:24:30 PM »
The Holley kit is higher quality and more specific than the generic kits. Worth the bucks.
Ron.
CDXXVII
« Reply #5 on: October 02, 2022, 11:44:34 AM »
Will the Holley 3-107 Renew kit work?
« Reply #6 on: October 02, 2022, 08:23:53 PM »
The generic kits were all of low quality. I gave up on them.
I’m picky and have 6 different parts vendors to make the kits I use…
This year I started offering them to others.
If you want an exact Ford 3x2 rebuild kit, I have them on my website afscarbs.com
Also kits for CJ, Boss, Lemans bowl, etc specific Ford stuff.
These are for real rebuilds, not just regaskets. I have idle well plugs etc so you can remove the old ones and clean the idle feed restrictions, etc.
winr1
« Reply #7 on: October 04, 2022, 06:35:48 PM »
.. an again, thanks guys !
Drew, thanks, I will direct any that ask to ya website
Ricky.
