Author Topic: FORD RACING FLYWHEEL  (Read 7650 times)
Dumpling
Re: FORD RACING FLYWHEEL
« Reply #15 on: August 18, 2022, 10:57:06 PM »
I'd appreciate it if someone could enlighten me as to the differences between a regular vs. a "racing" flywheel.
pbf777
« Reply #16 on: August 19, 2022, 10:51:51 AM »
............. the differences between a regular vs. a "racing" flywheel.
     Generally one would define the "racing" flywheel as a non O.E.M. after-market, something other than a "replacement" intention.   :)
     Scott.
shady
« Reply #17 on: August 19, 2022, 11:41:17 AM »
 I'd say a good racing fw has a SFI rating.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #18 on: August 19, 2022, 02:45:19 PM »
The name.  Well, like Scott says, something that is SFI rated and maybe lighter then a stock wheel and NOT cast iron.
A real racing wheel may also have replaceable steel inserts so that if the inserts warp you just drill out the rivets and replace the insert.  This is typically used on aluminum flywheels but I don't see why not a steel wheel?  Most race cars use alum wheels as it has less weight to accelerate...hence a faster ET.
