Author Topic: 390 smoking while holding back  (Read 9182 times)
Tunnelwedge
Re: 390 smoking while holding back
« Reply #15 on: July 20, 2023, 05:58:01 AM »
Hello. What your explaining sounds like a gasket sucking oil. The PCV system you show sucks to the plenum. That would make smoke out of both sides of the exhaust. You say the driver only so the lower edge of the driver intake is probably loose. I would just put a wrench on the intake bolts and snug them down and see if that helps. Pic of this trailer and towing rig?
390owner
« Reply #16 on: July 20, 2023, 06:25:08 PM »
I will remove the filter and see what happens. I have checked the bolts all are tight. Let me find a picture of it hooked up to the camper
390owner
« Reply #17 on: July 20, 2023, 09:48:30 PM »
IMG_5546 by Daniel Crymes, on FlickrIMG_1546 by Daniel Crymes, on Flickr
Tunnelwedge
« Reply #18 on: July 21, 2023, 04:01:04 AM »
Nice looking rig.
TJ
« Reply #19 on: July 21, 2023, 07:39:53 AM »
Have you looked at all the plugs yet?
390owner
« Reply #20 on: July 21, 2023, 07:36:32 PM »
Yes clean
SMorton67FB
« Reply #21 on: July 22, 2023, 08:00:42 AM »
Could be the exhaust valve guides are shot and leaking there.
