Author Topic: Christmas in June - Comp Rockers  (Read 4142 times)
JC-427Stroker
« on: June 10, 2022, 06:37:07 PM »
After many months of supply chain issues these babies were shipped on Tuesday and showed up today.
Nice looking piece to add to the Survival Motorsports MR heads I've had for quite a few years now. Maybe by the end of the year  we'll start bolting the engine together. I still need to figure out the cam I'm going to run.
https://www.flickr.com/photos/195460141@N05/52137655110/
https://www.flickr.com/photos/195460141@N05/52137183858/
« Last Edit: June 11, 2022, 04:32:29 PM by JC-427Stroker »
JC-427Stroker
Re: Christmas in June - Comp Rockers
« Reply #1 on: June 10, 2022, 11:37:31 PM »
https://flic.kr/p/2nrbGk5
I'm stumped  ... On this board how do you get a picture posted ?
« Last Edit: June 10, 2022, 11:40:29 PM by JC-427Stroker »
« Reply #2 on: June 11, 2022, 05:13:16 AM »
It's a little convoluted.
When you bring Flickr up, click on the little icon that looks like an arrow going to the right.  When it brings up another window, copy and paste the link in the box. Remove everything before the first [img] and everything after the second [img].
« Last Edit: June 11, 2022, 05:16:58 AM by blykins »
« Reply #3 on: June 11, 2022, 05:17:32 AM »
JC-427Stroker
« Reply #4 on: June 11, 2022, 01:35:43 PM »
Thank you.  That is a bit convoluted.   I'll give it a try:
IMG_3645"><img src="https://live.staticflickr.com/65535/52137183858_d06fc50b3a_z.jpg" width="640" height="480" alt="IMG
So much for that attempt .... I'll try again later.   Thanks
« Last Edit: June 11, 2022, 01:41:47 PM by JC-427Stroker »
« Reply #5 on: June 11, 2022, 04:10:44 PM »
You just have to use the image tags around the link.  Unfortunately if we try to type exactly what you need to do here, it thinks you are trying to post a picture, and won't let you.  So I will try to explain.
In what you posted that started with IMG_3645, get rid of everything up to and including the quotation marks, and replace it with the letters img , surrounded by square brackets.  Then, get rid of everything from the quotation marks on at the end of the link and replace it with /img  , surrounded by square brackets.
Here's a picture of what your text should look like, showing the image tags:
I grabbed your link and modified it with the image tags, posted below.  By the way, the information on posting pictures is also in the "FE Power Information and Rules - Please Read" sticky post, if you ever need to refer to it again.
JC-427Stroker
« Reply #6 on: June 11, 2022, 04:28:29 PM »
Thanks J.
Mr Woodys Garage
« Reply #7 on: June 12, 2022, 11:24:34 AM »
Look Like Some Nice Pieces. Is It The Photo Playing Tricks On My eyes, Or Are These Set Up With Offset Intake rockers to move the pushrods away fron the intake ports in the intake manifold? I know they make them, but wondering if you ordered them like this or is this how they usually build them?
JC-427Stroker
« Reply #8 on: June 12, 2022, 12:24:53 PM »
There is an offset. They build them that way.  I'll get a closer picture of them.
