Author Topic: BK/BJ carbs lesson  (Read 17057 times)
BK/BJ carbs lesson
« on: May 11, 2013, 06:12:10 PM »
Hi Guys
Ran into something I know nothing about.
BK and BJ carbs.
I've done a little research but can't find anything in depth yet.
Will someone shoot me a link or recommend a book or anything.
Wouldn't mind one of you talking about them IF you feel like typing.
I'm in sponge mode.
Thanks in advance.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
Re: BK/BJ carbs lesson
« Reply #1 on: May 11, 2013, 08:06:23 PM »
I'm not sure what you know about those carbs but I'll share what I know! LOL
 C3AE-9510-BJ Holley list 2804 (rear carb), C3AE-9510-BK Holley list 2805 (front Carb), No Choke butterfly, 600cfm
matching carb, used on 63 1/2 - 65 427 Ford/Mercury, 67 428 Shelby GT-500. 4160 Series
« Last Edit: May 11, 2013, 08:09:42 PM by Ford428CJ »
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #2 on: May 11, 2013, 09:25:59 PM »
That's new info BJ rear BK front.
No choke.
Was there any special metering.
What cfm were they.
Why are they so special/expensive to buy?
fetorino
  • Tunnelport Cobra
« Reply #3 on: May 12, 2013, 01:49:18 AM »
The carbs have a different metering that the std small Holley 600s.  Here are some detailed specs.
http://www.network54.com/Forum/74182/thread/1162924197/BJ-BK+carb+Specifications
GJCAT427
« Reply #4 on: May 12, 2013, 05:37:53 AM »
That info should be in the holley books. Everyone seems to think there`s some voodoo to those carbs. If you read down the replys you`ll see my signature stating that a Holley tech told me they were the same yrs before.  Chipmechanic confirmed what the tech told me. I run a set of 1850-2s on my 63 427 galaxie and it has excellent street manners. I`m running repoped BJ-BKs on my 427 powered 56 F100 and there is a slight difference in manners, the truck has a bigger factory cam than the car. If for some reason you want to run 1850s use -1,-2,-3, The latter ones have been changed, and don`t respond as nicely as the older ones.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #5 on: May 12, 2013, 09:12:39 AM »
No choke.
What cfm were they.
Like I posted 600CFM. The metering blocks are 4033. Why are they so expensive.... Those are Factory Carbs and what they go to.
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #6 on: May 12, 2013, 10:12:57 AM »
As near as I can tell the real big difference is the postion
of the trunnion on the throttle shaft.
BK upper
BJ lower, it's about 5/8" lower.
And that hole that Mike measured.
Disclaimer: those are not my carbs, I lifted the pics from the spider web.
These carbs have the throttle shafts in the wrong carbs.
You can find these pictures at
http://mustangtek.com/4160/holley4160.html
My carbs are old and crusty. Like me.
Heres a pretty good TSB on them.
http://www.427galaxieregistry.com/1964tsb.html
More disclaimer. lol
Even the TSB has some errors.  ::)
« Reply #7 on: May 12, 2013, 01:19:56 PM »
Very cool stuff
Thank you gents
I've been studying multi carbs lately as I just purchased a tri power for my Tbird rebuild coming up.
Appreciate your time.
BTW The TSB was a key to a whole new info stream. Thanks Howie.
« Last Edit: May 12, 2013, 01:48:26 PM by turbohunter »
MT63AFX
« Reply #8 on: May 20, 2013, 06:48:27 PM »
Do you have the T-Bird specific 3x2 intake? It's different from the Galaxie 3x2 intake, which will not allow the hood to close because the carb bases are slanted, Rod.
« Reply #9 on: May 20, 2013, 06:52:03 PM »
Yes I do.
Thank you
