Author Topic: Edelbrock's new carb VRS 4150  (Read 12279 times)
Re: Edelbrock's new carb VRS 4150
« Reply #15 on: December 09, 2021, 07:14:53 PM »
Yeah, all these backorders really suck, I need a new pair of slicks for my Fairmont. Before Covid, it was no problem, the local Speed Shop always had them in stock, but have not had any in almost a year. And since moving, I had a different shop check for me, he said Mickey Thompson doesn`t even have any on hand, so he won`t even place an order until they do. Could be worse I suppose, at least I don`t have a car or engine in pieces, being held in limbo by a lack of key parts. (although I certainly wish the availability of aluminum FE heads would get up to speed soon.)
« Reply #16 on: December 09, 2021, 09:41:47 PM »
Ha, I got a shit pile of parts and no one to do the machine work. Had it all at one shop for 7 weeks and they never touched it. Picked it all up and took it to another shop and it's been there for 5 weeks now. About ready to go pick it all up again.
« Reply #17 on: December 10, 2021, 07:08:21 PM »
Got to hold one in my hands today at PRI. Very nice looking carburetor. They are offering a 650, 750, 850, and 950. 650 cfm is downleg booster. All 750-950 will be annular. The first few pics are the 650, the last couple were an 850 I believe. Billet metering blocks with changeable emulsion bleeds and power valve channel restrictors. Notched floats with jet extentions, baffled bowls, and bowl drains. Has an air bypass valve/screw through the top of the venturi. TPS provision and throttle shafts are bronze bushed. Dual bolt pattern 4150/4500. 650's are expected to be released first in the first quarter of next year.
« Last Edit: December 10, 2021, 07:52:49 PM by Nightmist66 »
GerryP
« Reply #18 on: December 10, 2021, 07:53:17 PM »
Looking at that makes me think tuning a three-circuit Dominator would be pretty easy.  I guess the additional bleed support something like an intermediate circuit.
« Reply #19 on: December 10, 2021, 07:58:25 PM »
Yes, it has an intermediate circuit for additional tuning. Some other features I'm forgetting, but I don't think you will find anything else even close in price range for all the features. I think the 650 was starting somewhere between $700-750 and the rep said each size larger is an additional $50 or so. One thing I forgot to add is that is just a little taller than a Holley/ Quick Fuel.
« Last Edit: December 10, 2021, 08:00:06 PM by Nightmist66 »
475fetoploader
« Reply #20 on: December 10, 2021, 10:53:11 PM »
Thanks for the pics and information.  It looks like a nice piece to me.
1967  519 c.i.  TKX 5 speed
« Reply #21 on: December 11, 2021, 02:24:38 AM »
What venturi to throttle sizes are the different cfm ratings? Is the largest throttle diameter 1.75?
StarlinerRon
« Reply #22 on: December 11, 2021, 12:20:41 PM »
Edlebrock has had a pissing contest with Holley for decades ever since Holley started selling their own intake manifolds. So edlebrock started pushing revived Carters. Finely they decide to build an Autolite/Holley mixer.
Seems that the annular boosters should be on the smallest carb for good street manners. (there was a patent on annular boosters for years that kept Holley & Carter from selling them.)
Maybe now they will recast their 2x4 intakes so two Holley style carbs can be used.
Ron.
427LX
« Reply #23 on: December 11, 2021, 03:11:51 PM »
That is a wild looking carb with great features. Look at all those air bleeds you might need!  The 750 carb has 1.250 venturies....how do they flow that much?
BigBlueIron
« Reply #24 on: December 13, 2021, 09:46:13 AM »
Ron.
Now wouldn't that be nice.
« Reply #25 on: December 13, 2021, 11:53:20 AM »
Ron.
These won't fit Ford med 2x4 either , bowls are way to deep and metering blocks at both ends , unless you can turn the carb sideways they are just physically too big
« Reply #26 on: December 13, 2021, 12:12:28 PM »
I ordered a Canton road race pan and pickup from Summit last tuesday and recieved it on last thursday.
Greg
Would be nice - Milodon is the only mfg making the pan I need.  The only Canton pan for my app requires a dry sump system.
I might have to get one of the new 650s and see how that works on the door car.
« Reply #27 on: December 13, 2021, 08:16:30 PM »
Seeing all those removable bleeds would make me kinda nervous about them getting loose and dropping into a cylinder.
GerryP
« Reply #28 on: December 13, 2021, 08:37:09 PM »
If you drop one, you have to fight yourself to resist opening the throttle.  The way I handle bleeds is once I have them lose, I put a toothpick firmly in the hole and finish unscrewing them and take them out.  Same for putting them back in.  I have yet to drop one.
« Reply #29 on: December 14, 2021, 09:11:14 AM »
Damn good idea!!
