Author Topic: Front sway bar for 1966 Fairlane?  (Read 8346 times)
66FAIRLANE
  • Andy
Re: Front sway bar for 1966 Fairlane?
« Reply #15 on: October 21, 2021, 05:15:39 PM »
When I built the larger sump for mine I didn't worry about the 'layback' toward the bottom front of the standard sump, I just went straight down (as can be seen in attached pic). Simpler and I get a bit more volume. When I installed the engine it all cleared no problem....until I bounced on the front end! Oh, thats what that layback is for! As you can imagine this was a major bummer after slipping in a fresh drivetrain. Luckily I came up with a simple solution. Shortening the link connectors places the sway bar at a different angle and everything clears. It also had the effect of stiffening it up.
