Author Topic: Factory Forged 428 $ Crank?  (Read 19398 times)
bulletpruf
    • The Bulletproof Garage - YouTube
Re: Factory Forged 428 $ Crank?
« Reply #15 on: July 19, 2021, 06:01:56 PM »
I had one of those C4 steel cranks, swapped it to Bobby Spears for his Lightweight. It was std and cherry, don't remember if it was cross-drilled, no grooves. In the possession of Cragar Wenger now
MeanGene -
Was it a 3.78 or 3.98 stroke?
Scott
Please check out my YouTube channel for vintage car and truck rescues, builds, and shenanigans!  https://www.youtube.com/c/THEBULLETPROOFGARAGE/videos
bulletpruf
« Reply #16 on: July 19, 2021, 06:05:19 PM »
The subject of the C4AE-6303-G forged cranks has come up here, and on the old FE Forum, in the past, and last summer I posted these pictures of one that was in our local friend Kurt G’s collection. To be clear this particular one, and the others I’ve heard of are 3.78” stroke cranks. From information in the past the C4AE-6303-G cranks were part of a 7000 rpm kit Ford offered racers for the 427 High Riser. I asked last year if anyone had a copy of the original Ford memo, since it’s disappeared from the old FE Forum post, but no one posted a copy. I would guess maybe Dennis K. has a copy of the memo. These were a non-cross drilled crank, unlike most of the later 427 forged cranks. This one has the grooved mains which were common on 427 cranks at the time. Hard to tell just from the pictures, but the rod journal on this seems to not be quite as close to the edge of the crank, which would maybe be expected if the other crank was either ground as a stroker, or welded and offset ground. All just speculation at this point, but possible the C4AE-6303-G crank Bulletpruf posted was a raw C4AE-6303-G crank that was finished in 3.98”, or possible it was modified. In any case, a C4AE-6303-G crank wouldn’t normally be a 3.98” stroke crank, so why it still has that engineering number would be more speculation lol.
Kevin -
Thanks for taking the time to post the details and the pictures.  I really appreciate it.
Scott
427FeWedge
« Reply #17 on: July 19, 2021, 07:29:29 PM »
We need to redefine this being not a Ford OEM 3.98 stroke crank but an OEM forging. My understanding is they were shipped as unfinished cranks.
I'll try to drag mine out to see if they is any vendor stamp like Hank the Crank, Reath , Velasco or H&M on it.
Rob
bulletpruf
« Reply #18 on: July 19, 2021, 07:55:01 PM »
Rob
Thanks for the clarification.  Please let me know what you find.
Scott
BH107
« Reply #19 on: July 19, 2021, 09:04:06 PM »
I have one of those C4AE-6303-G steel high riser cranks as well, 3.78” stroke and the early cap screw rods that go with it.
I am fairly sure this forging was used through 67 with different final machining instructions, thus the modified (ground and re-stamped) versions used for later 427 versions.
I wonder if this was just a raw forging that somebody had ground with 3.98” stroke. If it had been a Ford cheater crank it would likely have had the casting marks modified like the later cranks to match.
FERoadster
« Reply #20 on: July 19, 2021, 10:00:11 PM »
MeanGene: Cragar Wegner? or Eric Wengen in Elizabeth Colorado? Quite sure he bought Bobby's car and installed a SOHC. He's now building a SOHC Willy's coupe.
Thread on HAMB.
Stopped by his place once because my In-Laws are only 5 miles away.
Richard >>> FERoadster
427FeWedge
« Reply #21 on: July 19, 2021, 11:28:49 PM »
I just checked my crankshaft and the only stamping I have found is on the bottom of the the front counterweight,
4134 (NFW, stacked).
Rob
428kidd
« Reply #22 on: July 20, 2021, 07:50:33 AM »
Richard, Cragar and Eric are the same . Mene Gene is using his nickname , out of his love of Cragar SS wheels.
427John
« Reply #23 on: July 22, 2021, 05:38:28 PM »
Another possibility is a welded and stroked 361 or 391 crank,that wouldn't be the first one done, back in the days before the availability of the stroker cranks we have today it wasn't unheard of for someone to take a steel 361 or 391 FT crank have it welded and stroked and have the snout turned down for pass car use.Thats how the whole stroker crank business got its start.Some of the more reputable shops did such fine work that it was hard to tell anything was done.
Regarding this, the 361 that I have and the 391's I've seen (3 of them), have distinct counter weights, that have a large radius.
Frank when one of the shops welded and stroked factory cranks there was usually some amount of reworking the counterweights too,in some cases they even added counterweights where there wasn't one before.Its also not uncommon to cut down the counterweight radius to make the crank fit into a smaller crankcase,an example being reworking a forged steel y-block crank to fit into a 289 block or a 454 chevy crank to use for a 348 stroker crank.
427John
« Reply #24 on: July 22, 2021, 05:55:28 PM »
It not a welded crank. I have the same crank and they started a C4 steel crank but they non cross drilled.
Rob
Unless you have closely inspected his crankshaft thats a pretty bold statement to make,while I agree that some of the unfinished forgings were likely finished with a 3.98 stroke as yours was many more were finished with a 3.78 stroke and probability is good that some of those were welded and stroked later.
« Reply #25 on: July 22, 2021, 06:26:33 PM »
John, we are talking about the OP's crank, right and it's origin?
If you'll look at Mikes pictures of the FT cranks, you'll see that there is no way that the OP crank could have been made from a FT crank. It doesn't have the markings or crank flange of the OP's and I don't think they would have welded up the radius on the counter weights. Plus the FT cranks are light and use external balance. Lastly, as someone else inferred, the crank bolt would be larger.
MeanGene
« Reply #26 on: July 22, 2021, 09:06:26 PM »
Really? I have a 391 crank that was welded and stroked to 3.98. Want to come and carry it around a bit? That mutha is heavy
427FeWedge
« Reply #27 on: July 22, 2021, 11:47:57 PM »
[/quote]Unless you have closely inspected his crankshaft thats a pretty bold statement to make,while I agree that some of the unfinished forgings were likely finished with a 3.98 stroke as yours was many more were finished with a 3.78 stroke and probability is good that some of those were welded and stroked later.
[/quote]
Well John it's not a bold statement at all. I've owned it over 30 years and looked at it very closely when I posted about the stamping on the counter throw. It is NOS, 3.98, 2.438 rod journal and not a welded stroker.
TimeWarpF100
« Reply #28 on: July 23, 2021, 12:34:26 AM »
Buddy of mine is a hardcore Ford guy who has been around a while.  He recently picked up some FE bits including an NOS 3.98 stroke crank with the $ sign.  Basically a 427 steel crank but with the 428 stroke.  He doesn't know if he wants to use this in a max effort build or sell it/trade it for a stroker crank.
I haven't heard of these, but did find this thread when I searched - http://www.clubcobra.com/forums/fe-talk/39236-stock-428-steel-crank.html
Anyone have any info?  Any ideas on value?
Thanks
Scott
Hey Scott! Good to see ya here!
wsu0702
« Reply #29 on: July 23, 2021, 02:44:24 AM »
What I find interesting is that every $ forged FE/FT crankshaft that I have ever looked at did not have that half moon cutout in the flange.
