Author Topic: how timing effects my engine.  (Read 10349 times)
mike7570
Re: how timing effects my engine.
« Reply #15 on: June 04, 2021, 11:59:25 AM »
Your 4:11 gear is not  your friend with 3500# car.  Try a 4.44, or 4.57.  Joe-JDC
Right here ^
and I will add the car is not happy with your set up. 600hp should have you in the low 1.40's to high 1.30's 60ft times. With the power it should be running low 10's.
What type of trans?  Any tire spin?  How do you leave the line?  what RPM shifting and what RPM at finish line?
I think Blair has a couple of different PP programs with one being a street version, I wouldn't mess with a head & cam change if it's already making 600hp.
« Reply #16 on: June 04, 2021, 06:49:54 PM »
If you want to go a little quicker and aim for running a 10.50 class, I would suggest some different cylinder heads or camshaft.
So what heads are you suggesting would suddenly pick up ET over Blair's Pro Ports?
As far as a head upgrade, I would try some ported TFS heads and a camshaft to match, or even have Blair go back into the heads that Jim has.
As Mike mentioned, there are a couple versions of these heads. The street exhaust and race exhaust. I believe Mr Jim here, has the race if memory serves correctly. I believe I heard that the same heads as Jim's on a different combo made 800hp or just north. I don't think the heads are the "cork". .500" lift on a race-only setup is leaving a little power potential with the heads being capable. I know reliability was in mind originally for the setup, though. I have the street version. They work just fine on an old dump truck engine.
1968galaxie
« Reply #17 on: June 05, 2021, 03:44:04 PM »
Are you saying TFS heads are an upgrade to Blairs pro Ports heads?
There are many incantations of Blairs Pro-Port heads. From mild to wild.
I haven't seen any TFS heads on 900+ HP builds. Blairs Pro-Ports - yes.
I would also think the OP could change his mild low lift cam to something more aggressive to pick up 60 HP.
« Last Edit: June 05, 2021, 04:00:54 PM by 1968galaxie »
« Reply #18 on: June 05, 2021, 05:12:37 PM »
Yes, I understand there are many incantations of Blair's Pro-Port heads, so yes, I would say that there would be some incantations where a TFS or a ported TFS head would be better.   I think this is one of them.   I also agree that a cam swap would pick up some horsepower.  Maybe not 60, but between some head work and a cam swap, I think it could be bumped up.
« Reply #19 on: June 05, 2021, 07:26:57 PM »
In my mind, 600 HP and 121 MPH does not make sense. It`s been many years since I raced a car with an automatic, but I know many people who found major improvements with different torque convertors. A racer that I know switched from a TCI convertor, that TCI built, supposedly after he told them his combination, to an ATI. Not only did the new convertor give him 6 MPH, but despite going much faster, it did so at lower RPM (less slippage), so he installed steeper gears, and picked up even more performance. What sort of finish line RPM are you turning at 121 MPH?
« Reply #20 on: June 05, 2021, 08:26:10 PM »
Rory I am in that 121 mph slot and I guess that my motor was making approximately 540 -550 horse in a 3500 lb car with me in it. I’m don’t think my motor is timing sensitive as far as speed wise. But I do notice how cool it runs when it’s advanced. I did a lot of tuning to get my times down and timing did the least. Jim were you advised to get a 5000 stall converter it just seems hi. I would just think 35 to 3800.
« Last Edit: June 05, 2021, 08:39:59 PM by Stangman »
Jim Comet
« Reply #21 on: June 06, 2021, 08:36:44 AM »
My converter is an ATI spec'd by Blair for my car. I am not sure what the stall is exactly as I don't have a data recorder and am pretty busy during launch. I should get or borrow a go pro to monitor my instrumentation during my runs and I could have a more accurate answer. I am not disappointed in the cars performance, I just want to move it closer to either 10.50 or 11.00 for my index racing class at BIR. ONE other thing is my rear gear ratio. While I am running 4.11 rear ratio, I do have the low gear set in my C6 with the 2.72 first gear. Would switching to a 4.56 gear be too low and force a really early 1st gear shift? Jim
« Reply #22 on: June 06, 2021, 10:10:27 AM »
Well if Blair spec it then he knows his setup
Royce
« Reply #23 on: June 06, 2021, 07:46:01 PM »
Brent.  Incantations of Blair's heads would imply supernatural powers, which some may attribute to them, but I am not sure that Blair would support.
Sorry just could not let that one slip by.. ;D  I think everyone knew what you meant to say
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
« Reply #24 on: June 07, 2021, 03:51:53 AM »
Haha, that’s not a word I would normally use but was using Perry’s phrase when I quoted him and replied to him.  I’m not smart enough to use that word on my own accord.
Gaugster
« Reply #25 on: June 07, 2021, 08:17:46 AM »
You might be able to evaluate the steeper gear option with a shorter tire. See if you have a buddy that could lend you some 26" slicks or pick up a set for cheap somehow? Assuming good traction you get some sense before committing to a gear swap. On the flipside if you do go 4.56 and it's too steep the 29" might get you out of a jam. Probably should run the math on the dimensions first though.
1968galaxie
« Reply #26 on: June 07, 2021, 09:56:41 AM »
Have you discussed any of this with Blair?
I am sure he would have a few suggestions to get you to 10.50's.
He does know his way around FE's.
I am sure he would appreciate being in the loop.
I recall an engine masters competition where an all iron Blair Patric 390FE made 596 HP @7100 rpm.  (Using C4AE-6090G heads)
I assume that EM dyno numbers are heavily scritinized.
https://www.hotrod.com/articles/iron-ford-390-fe-makes-596-hp-using-stock-heads/
Jim Comet
« Reply #27 on: June 08, 2021, 07:40:42 AM »
I have been talking to and am working with Blair. I am going to try a couple of things to see if I can move closer to the 10.50 index. As a racer my natural inclination is to gravitate to the faster ET. But if my changes don't work, I am fine with the 11.0 class. Jim
6667fan
  • Every Second Counts
« Reply #28 on: June 10, 2021, 08:35:39 AM »
Quite a problem you have there Jim, high 10s and 1.47 60’ times, lol. I think I mentioned it in an earlier thread that a data logger would answer a lot of questions. Since you are campaigning an FE you are already used to stimulating the economy.
 I came to this thread late. Usually check to see if anything has been added to the racing tab and this thread would have fit right in there IMO.
Please keep us posted.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
