Author Topic: 427 TP Marine Engine/ Austin Healey Roadster  (Read 57981 times)
Re: 361 Industrial Engine/ Austin Healey Roadster
« Reply #45 on: May 15, 2025, 03:46:08 AM »
I haven't updated this, for a very long time.
I went a different direction on it, regarding the engine, when Jay offered his TP heads. I found a 427 Marine short block and had it bored to 4.280, with a offset ground FT 390 crank, to a 4.115 or 473 CI.
I just got the heads back from Blair. He did his valve job on them and I have to clean up the chambers, blend the throat, into the port and give him the final cc to order the pistons. I also bought one of Jay's intake adapters for the TP heads and will make a TR intake for it, similar to the Weiand 351c, with 4500's on it, in a same manor as the 351c.
Re: 427 TP Marine Engine/ Austin Healey Roadster
« Reply #46 on: January 19, 2026, 04:29:31 PM »
I found the hood scoop I needed and I also found a Liberty Face Plate trans,with a short output shaft and a aluminum tail shaft housing.
« Reply #47 on: January 21, 2026, 07:47:55 PM »
I picked this Dominator manifold up today.
It may not be the one to goes on it later. Jay is doing some figuring on a tunnel ram manifold that I may be able to make into a IR.
mike7570
« Reply #48 on: January 23, 2026, 01:15:56 PM »
I had one just like it, twin 660’s were about two tenths quicker and 3 or 4 mph better than a single 1050.
« Reply #49 on: January 23, 2026, 06:56:51 PM »
I've got this 1250 to try on it.
If I get the IR, TR mounted, I've also got a pair of IR, 1150's (426 Hemi) to go on that hoping they are big enough for this.
