Author Topic: 0.030 piston availability for 390 - around 10,5 compression target  (Read 408 times)
66gtafairlane
  • 1966 Fairlane GTA
Hi,
Street 390.Stock 3.78 stroke and connecting rods. Currently bored 0.020 and has around 9.2 with L2291 pistons.
These pistons have 1.776" compression height and 10 cc dish/ recess.
Edelbrock RPM heads with 72 cc chambers.
Targeting for 10,2-10,8 ratio.
Have not been able to find any off-the-shelf pistons yet - is a custom piston needed ?
Thanks !
Ville Sievers
Finland
1966 Fairlane 390 GTA 428 stroker in works
1980 Fairmont Futura 6 speed 454 W stroker in works
chilly460
Re: 0.030 piston availability for 390 - around 10,5 compression target
« Reply #1 on: October 16, 2026, 04:22:06 AM »
Autotec 1000778
« Reply #2 on: October 16, 2026, 07:37:22 AM »
The Edelbrocks will probably run a little fat on the chamber size, probably closer to 74.
Another option is a DSS Piston, 5cc flat top.  Would put you at around 10.0-10.1:1 set up at zero deck at TDC with a .040" gasket.
66gtafairlane
  • 1966 Fairlane GTA
« Reply #3 on: October 16, 2026, 08:09:19 PM »
Ok, guess there is no easy way around this.The block needs to be decked. Now L2291A pistons sit 0.024" below deck and with -10 cc recess volume compression is 9.2.
Decking the block to 0 clearance and adding set of -5 cc pistons would bring the compression up to 10.0 - 10.2 with 0.040 gasket- perfect for this pump gas Galaxie.
Thanks for your input.
Ville Sievers
Finland
« Reply #4 on: October 17, 2026, 11:15:47 AM »
You can pick up a extra 1.1cc using a .038 x 4.33 Clevite/Mahle 3389 gasket, over the Felpro 1020 .041 x 4.40 gasket.
.038 isn't to close.
