FE Power Forums => FE Technical Forum => Topic started by: plovett on July 22, 2020, 03:41:22 PM
Title: Cross bolting cost?
Post by: plovett on July 22, 2020, 03:41:22 PM
I'm not sure if this should go in the tech forum soo...…
How much is a reasonable price for fitting Program cross bolt caps to a non-crossbolt block?  Including line honing (align honing?)
Thanks,
Title: Re: Cross bolting cost?
Post by: Gaugster on July 24, 2020, 09:48:05 AM
I think I read somewhere to budget 1k for adding crossbolts to a FE block. Totally anecdotal and I have no quote or sources though. Perhaps not a helpful response but maybe someone else will chime in.
Post by: e philpott on July 24, 2020, 02:55:46 PM
This might be get answered better in the tech forum , I'm thinking my cap labor was around 750.00 back in 1999-2000 from my local machine shop Performance Clinic , they did a great job too so take that into consideration on price , counter sunk and spot faced side bolts look really sweet and professional compared to what I've seen at the swap meets back when I gave up trying to find a good/used 427 block under 5000.00. BP has mentioned a couple times about leaving the thrust cap/middle cap alone as a cost effective way ( if needed ) of doing cross bolts and just do the outer caps  other wise there's a ton of time in setting up that thrust bearing cap and getting the measurements right on top of the cross bolt stuff , he thought it was just as durable too so that might be another option if cost are out of hand
Post by: SMA390 on July 28, 2020, 08:52:05 AM
Performance Clinic built my first 390 back in the early 90's..small world
a few years later I worked at Ault and James
Post by: My427stang on July 28, 2020, 10:01:25 AM
Paulie, my guy said 750 to install caps,  I'd say 750-1000 is realistic.
You didn't ask, but a good mag, square deck, torque plate hone, and (if required) tapping all oil galleys, runs about 860 here, if the block needs to be abraded, he adds 100.  I install cam bearings myself, so not sure what that would add, my guess says 100, same with sonic checking, I think 150 around here
Knowing the new project, my gut says, a good square decked, magged, sonic checked block, finished with pistons fitted, ready for assembly and the caps would bounce between 1600-1800 depending on what kind of additional work was needed.
Good machinists are a dying breed around here, COVID decimated what was already thin
Post by: 475fetoploader on July 28, 2020, 12:27:30 PM
Have you considered a girdle? I’m putting this on to try out. I’ve never done one before, not sure where we land as far as a strength increase if any. It looks beneficial.
Post by: blykins on July 28, 2020, 12:38:21 PM
The main girdles are nice, but they are a machining nightmare.
Post by: 475fetoploader on July 28, 2020, 01:55:05 PM
You’re making me nervous. All I did was set it on my Bridgeport, and cut the caps down the thickness of the spacers. Hopefully it’s ready for a main home now.
Post by: blykins on July 28, 2020, 02:34:46 PM
When we did one here, we had to make a pass across the pan rails.
Post by: rcianci on July 28, 2020, 04:19:59 PM
In reference to the main girdle ,there is a former ford engineer (I think) who sells a beautiful kit , out of wisconsin, for $395 US. Comes with everything you need. No machining, with full Instructions. I will be buying one when I refresh my 445. Kit is on epay. Thx. Bob.
Post by: blykins on July 28, 2020, 04:27:04 PM
That's the one I used.....there is machining involved.  Lots of it if you want to be accurate.
Post by: 475fetoploader on July 28, 2020, 05:55:14 PM
Can’t see where it’s possible without cutting the caps. I didn’t make a pass on the pan rail, however I had a lengthy process squaring the block on my mill. Then I cut all the caps to height so the spacers fit perfectly between the caps and the girdle. If this was done inaccurately, I believe you could wind up loading a bearing improperly.
Post by: Thumperbird on July 28, 2020, 06:00:56 PM
Forgive the inexperienced FE question.
Does the girdle mod reduce or eliminate the increased likelyhood of block split I an told about between the cam and mains on a 600hp plus engine?
Thanks.
Post by: plovett on July 28, 2020, 06:24:16 PM
Thanks.
Good question!  My feeling is yes, it would reduce the likelihood of the block splitting, but I don't really know.
pl
Post by: plovett on July 28, 2020, 06:26:15 PM
If one wanted to get crazy, one could crossbolt AND girdle the block.  The FE funny cars did that back in the day.  If you just couldn't or wouldn't use an aftermarket block.
pl
Post by: plovett on July 28, 2020, 06:34:57 PM
Thanks for the responses guys!  Keep 'em coming.  I like BP's idea of just crossbolting number 2 and 4 mains and leaving number 3 alone.
Would a half-fill of Hardblok reinforce the area between the cam and mains?
I know I am going to have to pay a considerable amount to crossbolt the block, nothing on an FE is particularly cheap, but I want to do it in a cost effective (relatively) fashion.
pl
Post by: plovett on July 28, 2020, 06:41:01 PM
I like the idea of a girdle on a Y-block design like the FE or big block Chrysler where it ties into the pan rail.  I think the halo girdles are not worth too much.  However, I like the idea of crossbolt caps better than the girdle.  As for the machining needed for a girdle, I am sure Brent knows.
Post by: plovett on July 28, 2020, 06:43:23 PM
Thanks.   My 427 block is likely too rough for practical repair and use.  So I am looking to use my current 428 block or buy another 428 block.
Post by: fekbmax on July 28, 2020, 07:03:43 PM
I cross bolt and girdle all my standard FE race blocks. Have been using Tim's girdle for quite a few years but it in no way is just as simple as cutting the caps down and bolting it on. I know that alto of guys may just do that and have no issues but as Brent said and Barry has said in the past theres quite a bit of machining that needs to be done. Block needs to be square decked, I recommend all the way around, but pan rails certainly. Align hone with girdle in place. So your looking at fitting cross bolt caps, squaring block, cutting caps, align hone, plus your decking and boring. If your bloc filling then that should be the first thing you do before any machining at all. Everything needs to be done in the proper order. Its A lot of work to do it properly but will make a good solid foundation of a FE block. JMO.
Post by: pbf777 on July 28, 2020, 07:18:36 PM
     Well, that's what they pay us the "BIG BUCKS" for,.......... right!        ::)
      Yes, some Bridgeport work was a nice start but,...........I'd be nervous if I were you!          :-\
      Yep, I would consider it mandatory!             ;)
       What is this, something from RONCO! (anybody remember them?  O.K. it's a joke!)  And I thought we southerners were bad for selling Yankees swamp land here in Florida!            :o
       Without covering all of the processes involved, but perhaps prepare one for what one might consider:  On the FE for this stud girdle fitment one would want to establish the dimensional relationships of the five main bearing bores bore radius loops, to the main bearing cap saddles, to the main cap bolt posts in height, to the pan rail with timing cover; ideally, this both as sets each individually, and as a set of ten including the circumference of the block and timing cover pan rail needing to be square in dimension.  The problem is after blueprinting out these dimensions as the block assembly is received from the O.E., not to mention issues created from service, including previous secondary machine work, so invariably...............
.        ........there is machining involved.  Lots of it if you want to be accurate.
     And perhaps some compromises, as one is following the previous machining operation of someone else, generally of less accuracy, but none the less involved the removal of material one can't readily put back.           ;)
     We have done this many times, but I still haven't seen the "BIG BUCKS" yet, as few realize what's really involved, the associated time and tooling, nor appreciate at least in what I would consider a proper fitment effort.  And yea, there are or will be plenty of testimonials of: Naaaw, all you gotta do is this and that and your done, you don't need to do any of that other B.S.!  But all I can say is GOOD-LUCK!          ::)
     Scott.
Post by: 475fetoploader on July 28, 2020, 08:20:57 PM
This is a great topic. I truly love the knowledge coming from this forum. I made several assumptions about my used block. I made several assumptions about the relationship of a girdle to a main line. One being if it’s aline honed, (bearing clearances coming out correct) you should have a solid foundation. My conversation with DG machine this week will look considerably different concerning my main caps, now that I have participated in this thread. This is not a replaceable forum. The other assumptions I made, were that the previous machine work, were correct, this block has been square decked for a prior build. I put the 4 outer pistons in, and checked deck height. All 4 pistons are .004 from the deck. That’s not blueprinted, that’s lucky rod center to center. I truly thank the experienced machinists, that take time to comment.
Post by: Drew Pojedinec on July 28, 2020, 08:50:42 PM
It is indeed a great thread.
I maintain my point of view that for my usage, If I had to put $1000 into crossbolts, I’d just save my pennies and buy an aftermarket block.
I’m just a dude tho, don’t need to meet any sort of racing rules.
Post by: Nightmist66 on July 28, 2020, 10:09:46 PM
Paulie, I had some custom cross bolt caps made by a local machinist for my block. I for the life of me can't find the receipt for the caps and block machining. He left the bore small so it could be finished to size with a line bore and hone. I found the receipts for the line bore-$250, and the line hone-$80. I had him make the caps to be very close to pan rail level, so it didn't cut into the main webbing much. From what I have seen in pictures, I believe the ProGram caps cut right into the webbing. Here's what mine looks like if you're interested:  http://fepower.net/simplemachinesforum/index.php?topic=7851.0
Bluef100fe / Cody makes or did make some cross bolt caps similar that are close to pan rail level, but require spacers. You would also have extra machining if using on on #3 main to accept the thrust bearing.
One thing I don't care for about the girdle is that yes, it does tie all the mains together, but it is not a registered fit on the pan rail. What I mean is that you are relying on the clamp load alone of the oil pan bolts to hold it down and keep from fretting, because there will be some extent of tolerance in the bolt holes at the pan rail. I suppose you could "pin" the girdle in a couple spots on the pan rail to prevent fretting, but would be extra work. Overall, it looks like a nice piece, just as mentioned though, a lot of careful machine work to make it right. JMO
Post by: blykins on July 29, 2020, 04:51:48 AM
To me, all that stuff is unnecessary for 550-600 hp builds.   I've done numerous 390/428 based strokers that make that much power and more, even some pulling engines that have to hold 6500-7000 rpm for 20 seconds straight making that kind of horsepower.  None of them are girdled or cross bolted.
In my mind, if you're gonna go find a block and pay $1000-1500 for it, then have to put another grand into fancy hardware to make it live, then you're not too far off from an aftermarket block.
Paulie, I think giving up on that 427 block is a very wise choice.   Not many guys would willing want to touch something like that.   You're trying to quote/price a job that's either gonna cost the builder a ton of money if he holds to his quote, or costs you a ton of money if they start quoting time/materials.
Post by: e philpott on July 29, 2020, 09:01:34 AM
When I did mine the aftermarket blocks were not out yet , swap meet after swap meet welded up junk 427's were 3000.00 and up for JUNK . So I got tired of that and took all my 390 blocks down to Performance Clinic and he picked out the D2 block that had 7 thick cores and one core off set super thick on one side and only  .115 on a non thrust side , we used that block to make a 416 and I told him I wanted 500 horse power plus a 250 shot of nitrous , Dave told me to buy some cross bolt caps and he'll give it a half fill , still running it hard to this day but never did get the nitrous . I do have a BBM block and Scat Forged crank at Blair's right now that I'm slowly getting money up for the additional parts but life keeps getting in the way of those additional parts
Post by: Barry_R on July 29, 2020, 09:39:43 AM
I probably covered a lot of girdle machining in an old post somewhere.
Because the girdle relies upon the oil pan rail and the main cap bolt registers for alignment and position ALL those surfaces need to be straight, square and parallel - otherwise you are inducing a twist into the block each time you tighten it, and that twist can vary depending upon it's location on the pan rail unless you provide location dowel pins.  While these surfaces were important individually, none of these surfaces were critical or referenced to one another in the original manufacturing.
This means the girdle installation process is roughly as follow:
- Line hone mains (unless you assume they assume they are reasonably decent to start off with)
- Use the main line as a reference to square and machine the oil pan rails.
- Use the pan rail as a refence to level and square each of the main cap bolt spot face surfaces.  You kinda need to do this one at a time with the opposite fastener holding the cap in position.
- Use the main studs and pan rail bolts to position the girdle where you want it to "live" and drill it and the block for locating dowel pins so you can always install it in the same position.  Might be a nice idea to add some countersunk fasteners in a few spots to make future assembly easier.
- Measure the distance between the bottom of the girdle and the spot face on each main cap to determine the required spacer heights.  The spacers supplied with a girdle might work, but probably not.  Make some spacers that fit on the lathe...
- Test fit everything.  Don't forget to accommodate for the girdle thickness when mounting oil pump, pump shaft, oil pan pickup, or pickup mounting bracket if using a mid or rear sump pan.  Best check the windage tray as well since the girdle thickness might put the tray into contact with the top of the pickup, etc..  Remember that the girdle will effectively drop the pan location relative to the chassis of the car - some installations are really "tight" down there.
You may now install your "bolt on" part.....no gasket between girdle and block, just some silicone should do the trick.
Post by: jayb on July 29, 2020, 11:11:27 AM
So, I'm curious about this because I plan to make a girdle for a 390 block for an upcoming project.  Barry, you said to use the main bearing bores to square the oil pan rail, and that will work to get the pan rail square front to back, but by itself the main bearing bores won't square the pan rail side to side.  The block could be tipped off that main bearing bore axis by some small amount.  Then, if you reference the spot face of the caps from the pan rail, and it isn't aligned quite right, then the spot faces won't be parallel to the bolt heads, which can't be good.
The only way I can see this working is if you have a BHJ fixture to bolt on using the cam bearing bores and the main bearing bores, and then indicate off the surface of the BHJ fixture that is parallel to the block deck to get the pan rail square side to side.  See the photo below.  Is that how this is done?
(http://fepower.net/Photos/Posts/R&R 022.jpg)
By the way, this thread really belongs in the technical section, and I will probably move it there soon...
Post by: Barry_R on July 29, 2020, 11:13:25 AM
Jay - you are correct
Post by: pbf777 on July 29, 2020, 01:36:30 PM
     This procedure, as I envision it as described, and I realize that this list is only a short synopsis of the process, but keep in mind the stud girdle plate rarely is found to be truly straight or square as received; so you would be making the stacking heights match the potentially imperfect plane presented by the girdle. Besides, if one executed the other machining operations properly then there should only be one dimension for all ten positions, with perhaps the exception depending, being the rear number five main cap.   And I also realize that there truly is no such thing as "perfect", but we're striving to be as close as our feeble abilities will permit.            :)
.....................,but by itself the main bearing bores won't square the pan rail side to side.  The block could be tipped off that main bearing bore axis by some small amount.  Then, if you reference the spot face of the caps from the pan rail, and it isn't aligned quite right, then the spot faces won't be parallel to the bolt heads, which can't be good.
      Yea, maybe-sorta, but your inquiry appears to be of bolt heads being parallel to the spot faced seating surfaces upon the main caps?  Who said the bolt holes were drilled and tapped perpendicular to the pan rail surface or parallel to the camshaft bore to main bore center line?  By the intention in the use of the BHJ Block-Tru fixture your implying that the O.E.M. may have presented critical machined surfaces of improper positioning, so why would one believe the bolt holes at least in of the apparent desired accuracy implied of the posting, be as in sync with this plane any better?           ???
      I understand how things seem like they oughta be, but so should others that we already know aren't;  but your intention sounds good, but remember, your following someone else's previous workmanship, sometimes you may have to compromise that which would be ideal for that which is acceptable and reasonable.           :)
      And, that doesn't imply being sloppy, just realistic.              ::)
     Scott.
Post by: WConley on July 29, 2020, 03:25:08 PM
Thanks.
A block girdle as shown above won't do as much to help the FE cracking problem on #2 and #4 mains.  It WILL do a great deal to stabilize the caps / prevent cap walk.
Cross bolts are much more effective because they tie the block skirt directly into the sides of the center caps, to better absorb side loads.  The girdle can't do this as well because it's only on the pan rail plane.
The girdle also depends upon clamp force to tie to the pan rail.  This is not as solid a connection as the side of the cap being hard up against the skirt.  Little things like this make a huge difference for the loading of the block.
Post by: gregaba on July 30, 2020, 09:54:31 AM
Just talked to my machinist this morning about when he will be able to get to my Pro Gram caps install. Looks like 6 more weeks.
He is going to install the caps, and blueprint the block with all the upgraded machine work needed to make the block right.
The cost will be between $800.00 and 1200 for the complete job.
I think this is reasonable for the amount of work involved in the job.
Greg
Post by: Dryhoze1 on July 30, 2020, 12:07:16 PM
I've had several done.
QMP out here in southern California has always done mine with great results. Shop located in Chatsworth,CA.
usually $800-1200 after everything is squared up and line honed.
The piece of mind is nice.
Good luck
Brian
I'll upload pic..
Post by: e philpott on July 30, 2020, 12:51:14 PM
Pro Gram caps look so nice I'd be tempted to buy a clear oil pan if Jay made one
Post by: plovett on July 30, 2020, 09:36:56 PM
Those are gorgeous.
Post by: plovett on July 30, 2020, 09:39:33 PM
Good luck
Brian
I'll upload pic..
Looks fantastic!  Thanks.
Post by: Falcon67 on July 31, 2020, 10:06:13 AM
Quote
I would tend to agree.  I've seen a lot of SBF blocks come apart, split down the middle, oil pump and front main fall off, full cams become 3/4 or 1/2 race cams, etc and things like girdles and those cheesy "braces" that some people install that go across the valley under the intake only serve to keep the pieces together for easier extraction from the vehicle.  As opposed to it falling apart on the engine stand when you remove the pan and intake.   If you want assured block integrity, it's the age for shelling out for a re-engineered aftermarket replacement, or dial the power down.  Even SBF blocks are getting hard to find, that can be machined back into service anyway.
Said the guy pushing 575+ through a stock D2AE iron Cleveland block.  Just waiting for "that day", when I get to tell the wife "It's time to call Tim Meyer and hand him about $3600".
Post by: My427stang on July 31, 2020, 06:56:47 PM
Quote
I agree with this as well.  To me, the girdle likely does very little for dissipating the harmonics from the cap to the block, which would be the primary goal to keep the bottom end together.  I just can't see how the oil pan bolts, even with a gasket on only one side, do much.  I think it would be better to recess bolts into the pan rail, machine nicely and bolt it solid with sealant before the pan.  Basically make a bed plate like a modern diesel
Now that being said, it likely transfers something to the other caps, and like you said, probably keeps the caps from moving a little. I just think it's likely more of a feel good than a significant increase in rigidity.
Now once that thing is bolted solid in many places, and maybe pinned to the caps, different story, but a lot more $$ and machining too
Post by: BattlestarGalactic on August 03, 2020, 09:44:36 AM
My .02 on the girdle.   I agree, I don't think it does as much as cross bolting.  Seems kinda flimsy overall and unless you pin it to the pan rail and some how pin it to the caps everything will still move around in the bolt holes.  Kinda like Keith says, it will hold the parts together so you can remove the blown up motor from the car.  Oh, I remember those SBF girdles using 10-32 SHCS holding the valley together>>>LOL!!!!
I did my own machining on my old 428 block to install 427 caps using our big G&L horizontal mill at work.  Worked out pretty easily with stock caps as then you only have to fit the bushings individually.  Mine worked well for 20 yrs and is still okay after putting a sleeve in it from last summer.  It's wrapped up waiting on its next use.  If it wasn't 3/4 filled, I put it together for my blower car.
I kinda cringe at the Program caps as you really have to watch your block machining to get the proper fit between the rails.  No fudge work allowed, you have to be dead on.  My thought was to eliminate that was to cut the caps and install spacers like a stock cap.  In this manner, it loosens the machining tolerance on the block, giving us part time machining hacks some leeway.  ;)
I too have seen more power put through 2 bolt caps, but mine only went one season before there was fretting on the mating surfaces, and that is when I installed the cross bolt caps and eliminated that issue for 2 decades of racing that block.
Post by: Joe-JDC on August 03, 2020, 10:07:58 AM
My block girdle that I use has a recessed nut area so that the oil pan sits flush with the girdle.  I use a thin bead of silicone on the block rail, then the girdle with studs, self locking serrated nuts, then oil pan gasket and oil pan with more self locking serrated nuts.  The girdle is torqued in place by every oil pan stud, then the pan is installed like normal. 1/2" steel plate girdle shaped for stroker clearance.  I use ARP main studs and torque the mains, then add a hardened washer on top of the nut for exact fit for the girdle, and another ARP nut torqued.    Joe-JDC
