FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: rockhouse66 on July 18, 2020, 09:59:42 AM
Performance Summary:
Cubic Inches: 445 Dyno brand: Land & Sea Dyno Mite
Power Adder: Where dynoed: Precision Machine - Sevierville, TN
Peak Horsepower: 504 @ 5450
Peak Torque: 563 @ 4000
Horsepower and Torque Curves:
Engine Specifications:
Block brand, material, finished bore size, other notes: FE 390 iron block, 4.080 bore, ARP main cap bolts, cylinder head studs
Crankshaft brand, cast or forged, stroke, journal size: Scat 4.25 stroke
Connecting Rods brand, material, center to center distance, end sizes, bolts: Scat H Beam 6.700
Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Mahle forged, -18cc, 9.9 SCR
Main Bearings, Rod Bearings, Cam Bearings brand and size: 125M mains, Speed Pro 7200CJ rods
Piston rings brand, size, other notes: Mahle 1.0mm/1.0mm/2.0mm
Oil Pump, pickup, and drive: Melling HV, Milodon pickup, ARP driveshaft
Oil pan, windage tray, oil filter adapter: Milodon deep pan, solid style windage tray with scraper, C8 FoMoCo adapter
Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050") Comp solid flat tappet, Lykins Motorsports custom grind 283/291 @ .015, 246/254 @ .050, 109 LSA installed at 102. .550/.576 gross lift
Lifters brand, type: Ferrea LF1003 Ultra Lite Solid
Timing chain and timing cover: Ford Motorsport, stock FoMoCo cover
Cylinder heads brand, material, port and chamber information: C6AE-R ported by Les Schmader - no info provided. Stainless CJ valves 2.02/1.65, drilled for CJ 16 bolt exhaust pattern
Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):
Intake Exhaust
.100 .100
.200 .200
.300 .300
.400 .400
.500 .500
.600 .600
.700 .700
.800 .800
Flow bench used, location:
Intake valve brand, head size, stem size: SS 2.09 3/16 stem
Exhaust valve brand, head size, stem size: SS 1.65 3/16 stem
Valve springs brand, part number, specs: Crane 1.460 OD, 130# seat pressure @ 1.85 installed height, 391#/in
Retainers and locks brand, part number, specs: ? Supplied by Schmader
Rocker arm brand, type (adjustable or non-adj), material, ratio Harland Sharp aluminum roller adjustable
Rocker shafts and stands, brand, material: POP HD shafts, FPP end stands and spacers, studs in cylinder head
Pushrods brand, type, length: Smith Bros. 5/16" Heat Treated 9.00"
Valve covers, brand, type: Cobra Jet cast aluminum
Distributor brand, advance curve information: Motorcraft w/Pertonix, all in at 2400 RPM
Harmonic balancer brand: Stock Cobra Jet C8 A2
Water pump brand, type (mechanical or electric): Stock FoMoCo C9 mechanical
Intake manifold brand, material, porting information: Performer RPM, port matched to heads.
Carburetor(s) brand, type Holley 750 DP with 1" 4 hole spacer
Exhaust manifolds or headers brand, type: Doug's headers w/tight bends, made for '68.5 Mustang Cobra Jet.
Here are photos on the dyno and the curve (PDF file on the top line):
Nice streetable combo. I ported a set of heads that I sent to Les for finish work and to have flowed and assembled, good to see that his stuff seems to work pretty well.
PM sent.
Curious why cut down CJ valves to 2.020"? The CJ valves would fit quite well. Joe-JDC
Joe - my error. The valves were standard CJ size; 2.09/1.65. I posted from memory and that is always dangerous. I edited my original build summary. Thanks for the question!
Looks like very nice reliable power.
How ‘bout a pic of the machine it is going in?
JB
This engine is currently for sale in the classified section, so probably no project car pictures to be had.
JB
JB
Correct. No suitable vehicle to put it in. This is the engine I SHOULD have built for the '69 Torino GT I used to have. Instead of fretting over date codes and engineering numbers which ran the $$$ up but not the performance.
