FE Power Forums => FE Technical Forum => Topic started by: chris401 on November 07, 2019, 07:52:23 AM
I called MSD about options for an electronic vacuum advance for a dual point that didn't offer a mechanical vacuum advance. I figured there would be a small discrete module that plugged into vacuum and worked with the newer 6&7 boxes. Seems like a simple concept. Has anyone figured out a way around running a vacuumless dual point distributor with an electronic advance?
You want electronic advance but not electronic trigger? Why not just throw a factory Duraspark distributor in with ignition box of your choice? More accuracy, energy, comparable reliability while gaining vacuum advance. And can be done with junkyard parts if you wish. Win win IMO
There are many ideas out there, one size does not fit all. I am just interested in an electronic vacuum advance.
Go to the website better dirt cheap ignition.
I read a few different threads. Is there a keyword or term that will get me to the right one?
Try better dirt cheap electronic ignition or ford tfi electronic ignition.pdf
I never did find anything. I do not recall any vehicles that may have used such a unit. I e-mailed him a week ago but have not heard back. Did you see mention of this?
For anyone too afraid to ask read this link:
http://members.iatn.net/forums/read/msg.aspx?f=forum2&m=499556&fv=0&ar=0
