FE Power Forums => FE Technical Forum => Topic started by: wayne on September 20, 2019, 02:32:26 PM
The slot in the front cam bearing goes to the front to oil the thrust plate right.
Yes sir.
Blykins thank you shop had it backwards i took it back had him fix it.He is good with fe we all can have a bad day he had a 427 in the shop same time as my 428. He said he has got some new cam bearing with out the slot in the front bearing
