FE Power Forums => Non-FE Discussion Forum => Topic started by: My3sonz on March 15, 2019, 06:20:53 PM
Hello. I am trying to get the car going for the FERR and am ready for the clutch. I have a Lakewood scatter shield and a G-force GF4A. The trans has a 26 spline input (bearing retainer OD is 1.375) do I use a GM fork, change the input and retainer, or does anyone know if they make a retainer with a larger ford size OD. Thanks
Spline count is not important. You can get a disc with any count you need.
Bearing retainer is generic, you can bolt a ford retainer on it(or call GF and ask for a Ford retainer for it). I run a factory ford big input retainer on my GF5R. The bolt patterns are the same. I had to change the seal inside to fit the different OD shaft(not a big deal, off the shelf seal).
The only thing that makes the input a Ford or Chevy is the length of the pilot and diameter.
My old Nash was a chevy input. I welded and recut the pilot to fit a Ford(since it is larger diameter anyhow).
Thanks Larry. Talked to G-force today. They are sending me the ford retainer. I am aware I have to trim the snout of the input (6.49? I believe?). And yes I have to order 26 spline disc still.
