FE Power Forums => The Road to Drag Week 2014 => Topic started by: jayb on August 18, 2014, 07:37:57 AM
Title: The Road to Drag Week 2014 - August 17
Post by: jayb on August 18, 2014, 07:37:57 AM
Just a quick update this week.  Family stuff kept me pretty busy during the week, but on Saturday I got back to assembling the car.  I received my new torque converter from Neal Chance on Friday, and also got some coarse filter screens to put on the dry sump outlets on the oil pan; I had decided that in case of an engine failure I wanted to try to prevent any shrapnel from getting into the dry sump pump.  On Saturday I got the dry sump filter screens installed and the lines modified so everything fit again, and after a certain amount of trouble I got the transmission reinstalled.  Took a lot longer to put it in than it did to take it out, of course... ::)
Sunday I put the front suspension back in the car, which also took quite a bit of time, and then finally mid afternoon I filled the engine with oil, topped off the transmission fluid, and fired the engine.  It ran for 20 minutes with the car still up in the air on the jack stands, and I didn't see one drop of oil or transmission fluid.  What a relief.  I've burned a total of three weeks on this problem; three weeks I didn't really have.  Drag Week starts three weeks from today!
Sunday night I got the wheels back on and put the car down on the scales, after I'd leveled them on the floor, so I could find the CG and get the height set at all four corners.  After I'd made all the adjustments the weight bias was 58/42, much more of a front bias than I'd been hoping for, but it is what it is.  Weight on the rear wheels was pretty close to 50/50 left to right, and the left front wheel was about 120 pounds heavier than the right front wheel.  I think this is about where it should be, given the propensity of a drag car to lift the left front wheel on launch, but I'm not 100% sure about that so I need to do a little research on that this week.
Next I checked the driveshaft angles and found that I had too much up angle on the pinion.  I ran out of time on Sunday to map the four link hole locations, but I'll do that next, get the bars in the holes I want to try to get a neutral launch, and then adjust the bars to bring the pinion angle down somewhat if that is still required.  I think this is going to be Monday night's project.
Last thing I did for the night was put my freshly painted hood in place to get a look at the overall appearance with the hood scoop.  Unfortunately, the throttle linkage that I spent so much time fabricating hits the hood  >:(  I will have to either trim the underside of the hood or revamp the throttle linkage; I haven't decided which yet.
I'm out of time now for testing, so getting to the track on Saturday this week is not optional, it is mandatory.  One way or the other, weather permitting of course, I will run the car next Saturday.  I'll post another update next weekend.
Title: Re: The Road to Drag Week 2014 - August 17
Post by: Cyclone03 on August 18, 2014, 07:56:33 AM
What's that saying about the last 10% of  project taking 90% of the time.....
Title: Hopefully something like these with increased surface area
Post by: Qikbbstang on August 18, 2014, 09:57:24 AM
http://www.drysump.com/screenfit.htm
       I also always install on every new filter a finger "nipping" magnet outside/over the oil entrance on the oil filters shell. When you cut open the filter opposite the magnet you will normally find nothing more then a small gray dab of Mayonnaise like feel consistency like paste - that's your motors rings/cylinder walls and is normal. You could NEVER see that paste looking at the used filter media - but it is cool to see how much your motors rings/walls are wearing.
Obviously if you have chunks of FErous particles opposite that magnet you know something's seriously wrong!
Title: Re: Hopefully something like these with increased surface area
Post by: jayb on August 18, 2014, 10:08:25 AM
Yep, that's what they look like...
Post by: cdmbill2 on August 20, 2014, 03:06:30 PM
Thank you guys for the post of the  dry sump screen link. I've been ullage to squeeze a full size  Peterson unit in the -16 inlet line for the external wet sump deal. I'm hoping they have what need.
Man this last minute stuff is a killer.
Post by: Royce on August 23, 2014, 01:56:03 PM
I wonder if Jay made it to the track today.....
Post by: Hemi Joel on August 23, 2014, 05:08:33 PM
Yup he did. Nothing broke...
Post by: cjetmech on August 23, 2014, 07:08:18 PM
YA!!! Come on Joel spill what you know!
Post by: thatdarncat on August 23, 2014, 07:55:31 PM
Just a tease...We're sworn to secrecy  :-X
(http://i1235.photobucket.com/albums/ff437/red0wl/Jaystestday005.jpg) (http://s1235.photobucket.com/user/red0wl/media/Jaystestday005.jpg.html)
Post by: Hemi Joel on August 23, 2014, 07:57:31 PM
I could tell you, but then I'd have to kill you. (http://board.moparts.org/ubbthreads/images/graemlins/OzBBQed.gif)
Post by: runthatjunk on August 23, 2014, 09:46:56 PM
hope that's not a pic of a newly discovered oil leak!
Post by: cjetmech on August 24, 2014, 06:29:06 AM
Mopar guys!!!! >:(
Post by: machoneman on August 24, 2014, 08:42:01 AM
Great news! I do have a question for Jay (w/o tipping off the competition).
Did the car perform as well as you had hoped?
Post by: jayb on August 24, 2014, 08:56:35 AM
No, but the air sucked and traction at this track was non-existent.  It was a good start.  More on my update later today...
Post by: Royce on August 24, 2014, 09:15:08 AM
Ahh HA   I thought I recognized that dragstrip.. The country's most expensive test and tune, and legendary lack of traction. Oh  I almost forgot the  hostile, and unwelcoming ownership and tech inspectors.......
Post by: machoneman on August 24, 2014, 09:26:09 AM
Thanks and yes, bad air and no traction makes for a frustrating time, for sure!
Post by: drdano on August 24, 2014, 10:35:04 AM
Is the laundry bag new, or always been on this car?
Post by: 57yblock on August 24, 2014, 10:48:10 AM
Ahh HA   I thought I recognized that dragstrip.. The country's most expensive test and tune, and legendary lack of traction. Oh  I almost forgot the  hostile, and unwelcoming ownership and tech inspectors.......   You pretty well hit the nail on the head there Royce.  But I have had a few good experiences there.
Post by: jayb on August 24, 2014, 12:17:05 PM
Al wasn't there, thank heavens... ;D
Post by: turbohunter on August 24, 2014, 01:29:56 PM
How bout this question?
Did you have fun?
Post by: thatdarncat on August 24, 2014, 03:21:35 PM
I'll answer for Jay. All his DragWeek cars have a receiver hitch for the trailer he tows. The parachute is attached to a mount that slips into the receiver hitch and is removable. So yes he's had it, just not always attached.
Post by: Heo on August 24, 2014, 05:59:37 PM
Jay It looks like you is up against a lawn mower in the other lane ;D ;D
Post by: Cyclone03 on August 24, 2014, 10:22:23 PM
I thought it was the push bar for the car . LOL
That was wrong I know..........
Post by: TomP on August 28, 2014, 06:34:49 PM
Was that Rock Falls, aka: Slippery Rock , the place called Ambergreen Dragway in the old days?
Post by: thatdarncat on August 28, 2014, 09:29:02 PM
Yup. It gets a pretty good Bracket race crowd.
