FE Power Forums => Private Classifieds => Topic started by: Mr Woodys Garage on February 24, 2023, 05:49:12 PM
I Have Decided To Throw A Bunch More $$$ At My Money Pit 428 Stroker Build For My 63.5 Galaxie, And Am Changing The Cam Before The Engine Is Re-Installed. My Loss, Your Gain. What I Have For Sale Is A Bullet, Billet Steel Solid Roller Tight Lash Cam. It was Installed And Mocked Up In My engine, With Morel Pressure Fed Solid Roller Lifters, And Pushrods Sized For Use With TFS Heads And Harlan Sharp Rockers (High Quality, Heavy Duty Smith Brothers Pushrods MAY Be For Sale At A Later Date, If They Are The Wrong Length For The New Camshaft) Cam Degreed In Perfect To Spec With Stock Crank And TFS Billet TC&G. Anyway, The Cam Specs At 242/248 At .050, 110 Separation, Gross Lift Is 598 Intake And Exhaust. 106 Intake Centerline. .008 Hot Valve Lash. The Specs Can Be Verified By Calling Bullet Cams, Using Serial # T38968, Sold To "Legacy Racing, Patrick Woody, (If You Want To Call Bullet Cams To Verify.) Needing $350. + Shipping Give Me A Call At 515-556-6484 If It Interests You. Thanks
Do you have a picture of the cam card?
Interested if still available
Sorry, Sold.
