FE Power Forums => Non-FE Discussion Forum => Topic started by: LMartell on March 09, 2021, 09:11:52 AM
I'm wondering which set of holes does the Zbar mount on the frame use ? I have a 69 Mustang 428cj converting from auto to toploader trans. The top of the frame rail has two sets of holes, the hole closest to the firewall isn't threaded. I am running my brake lines and line lock and trying to figure out where I have room to mount it all.
You need to put a nutsert (AMK) into the empty(rear)hole..Forward 2 holes are for small blocks and the rear two for big blocks.
427 Fastback , thank you
