FE Power Forums => FE Technical Forum => Topic started by: Tom Gahman on February 27, 2021, 07:11:30 PM
When adjusting your intake centerline,is" straight up" the same value as the LSA ?
A lower value would be advanced and a higher value would be retarded?
This is a cam that I used in my last engine, I have the cam card but there was no ICL or LSA info, don't know how
I set it that time, but I thought it was advanced. I called the cam co. and they said it has a LSA of 108, so
if I set ICL to 108 would that be straight up?
I've only done this four times and it always goes better on my friends projects
This is for a new engine for my Galaxie. When I get further along I'll post in the project section.
Thanks, Tom.
Yes.
Thanks, Frank, I really like your 54 project.
Thank you, Tom. I've always like the '54's.
