FE Power Forums => Private Classifieds => Topic started by: aj on February 02, 2021, 01:09:07 PM
Title: Ross stroker pistons/pins
Post by: aj on February 02, 2021, 01:09:07 PM
Bump  **Photos added in post below.**
Barely used Ross forged flat-top pistons and pins.  Used only for dyno break in and 3 pulls. Decided to replaced these with dished pistons to lower compression.
For use in a 428 block bored .032 over (i.e. 4.162" bore) and using 4.250 stroker crank with 6.700" rods (i.e. typical 428 stroker set up).
Here's basic info:
Intended block bore:  4.162"  (428 bored .032 over)
compression height: 1.312
(My 428 block had deck height of 10.155 and this resulted in pistons .020" in the hole)
Weight of piston & pin (no rings): 588 grams
Set up for 1/16, 1/16, 3/16 ring pack
These yielded 11:1 in my 428 engine with 10.155 deck height, 4.25 crank, 6.7 rods, 72cc iron CJ heads, .040 head gasket.
400.00 plus shipping from Texas.
Happy to provide additional info or text pictures.
Adrian
Title: Re: Ross stroker pistons/pins
Post by: Blueoval77 on February 02, 2021, 01:44:42 PM
Sending PM
Post by: aj on March 14, 2021, 09:52:29 AM
New price: 400.00 plus shipping from Texas
Post by: aj on April 26, 2021, 06:58:30 PM
Photos added.   $400 plus shipping.    Like-new Ross 428 (+.032 overbore) x 4.250 stroker pistons with less than 2 hours run time.  Happy to answer questions or send additional pictures on request.
Title: Re: Ross 428 stroker pistons/pins
Post by: aj on January 15, 2022, 10:55:53 AM
Bump.
