FE Power Forums => Non-FE Discussion Forum => Topic started by: james on January 14, 2021, 06:20:34 PM
Do you have the CVR water adapters that will fit the 385 series blocks, specifically the 460? If not what would you recommend? Thank You!
Nothing for the 385 series stuff, I only make FE parts. Meziere makes a good water pump, 55 gpm, for the 385 series, I'd probably go with that - Jay
