FE Power Forums => Non-FE Discussion Forum => Topic started by: ntheogen on December 14, 2020, 11:20:34 AM
My 19 year old nephew just moved to the Elk Grove California area to climb cell towers. He called me yesterday and a spark plug came out of his 4.7L Toyota Sequoia, I need to send him to a trustworthy and competent shop that can asses the situation for him. Anyone got any suggestions? Many thanks in advance
Jack
540 six six for for four one ate
Do you know if the spark plug came out from damaged threads, or possibly just unthreaded itself? I recently retired after the past 23 years at a Toyota dealership, and can not recall ever having a spark plug come out from damaged threads, but did have a few where the plugs had been replaced, but must not have been tightened enough. In each case, I was able to just either put the same plug back in, or if it looked questionable, install a new plug. Unlike my Ford V10, most later Toyotas have long threads for the plugs, close to an inch long, so chances are they threads are fine. I would just try to put it back in, snugly, and if it damaged the coil, install a new coil.
He's not super mechanically inclined, I was trying to figure out what was going on through a facetime call which was less that ideal. I had him try and run a spark plug tap in the threads and he was not able to do so and I was just getting frustrated. I think I found a decent shop in Sac to take a look and asses the situation. Thank you for your input and sharing your experience Rory, I will let you know how it unfolds. Happy Holidays to you and yours.
Jack
