FE Power Forums => Private Classifieds => Topic started by: mike7570 on August 10, 2020, 05:27:22 PM
Title: Back up 391 steel crank
Post by: mike7570 on August 10, 2020, 05:27:22 PM
For sale 391 steel crank - SoCal area $850 + shipping
Recently finished machined and nitride for FE use by Castillo's in La Mirada, CA.
Stroke 3.99,  Rod Journal BBC std. 1.90 width, mains -.010.
Reason for sale - I found out that the balance cost was going to be excessive using a NHRA mandated rotating assembly weight for a stock eliminator 428. The bob weight was 2207.
The crank will balance at a much lower cost using light weight rods & pistons (I do not have an estimated cost for that, it's up to you)
Title: Re: Back up 391 steel crank
Post by: mike7570 on August 20, 2020, 12:09:41 PM
for sale again.
Post by: wcbrowning on August 20, 2020, 06:13:59 PM
Was the crank snout turned down to standard FE dimensions?
Post by: mike7570 on August 20, 2020, 11:35:35 PM
Yes, 1.375 diameter
Post by: cwhitney67 on August 27, 2020, 07:54:42 PM
Mike you should keep the crankshaft and use it. NHRA never looks at the balance.
Post by: bluef100fe on September 04, 2020, 05:32:35 AM
If a guy had a 4.350 bore block with that crank would be a lot of fun for a open stock pulling truck with a set of high riser heads... and a 1030 three barrel carb..
Post by: BigBlueIron on September 04, 2020, 09:00:51 AM
Word!
Post by: bluef100fe on September 05, 2020, 05:47:08 AM
I just need a big bore block lol
Post by: TomP on September 27, 2020, 03:28:34 PM
I thought Stock Eliminator had to use factory rods or only certain part numbers of aftermarket rods that have stock length and journal size. Has that changed?
Post by: thatdarncat on September 27, 2020, 03:42:05 PM
There are specific NHRA “accepted” rods that have the BBC rod journal size.
Post by: mike7570 on September 27, 2020, 11:52:48 PM
There are numerous rods available for factory journal cranks but only one crower rod for the BBC dimensions. There is a minimum weight for the piston and rod assembly that also needs to be maintained and that’s why my 391 crank is for sale. If I put the balancing cost toward a new Scat crank and sell the steel 391 I actually save money. If I don’t sell it I figure I can keep it and use it for playing outside of stock eliminator. Maybe something with Jays new heads.
Post by: mike7570 on June 22, 2021, 06:17:46 PM
Crank still for sale, inflation has not affected the price, yet :)
