FE Power Forums => FE Technical Forum => Topic started by: olman on August 09, 2020, 07:54:00 PM
Title: sway bar
Post by: olman on August 09, 2020, 07:54:00 PM
 Does anyone make a heavier duty sway bar for the 63-64 Ford Galaxie?
Title: Re: sway bar
Post by: drdano on August 09, 2020, 09:53:52 PM
Quickor makes a 1" front bar.  http://quickorgarage.com/CartPages/ford1.htm#gal. I have their rear on my '62 wagon and it makes it less....sea-sickish in the arse.   ;D
Title: Re: sway bar
Post by: Gregwill16 on August 10, 2020, 06:30:26 AM
Here is one that is about half the $ of the Quickor but they are about 2 weeks backorder.
https://www.jegs.com/i/ADDCO/020/2098/10002/-1
Title: Re: sway bar
Post by: shady on August 10, 2020, 07:01:03 AM
you also need one of these.
https://www.ebay.com/itm/63-64-Ford-Galaxie-Offset-Shaft-Stabilizer-Bar/251446444227?hash=item3a8b6040c3:g:KrgAAOSw~bFWHxNw
Title: Re: sway bar
Post by: Lowrider on August 10, 2020, 07:09:19 AM
I have an Addco bar on the front of my 61. Works great.
Title: Re: sway bar
Post by: Falcon67 on August 10, 2020, 09:45:42 AM
Big front bar will help, but beware that increasing roll stiffness in the front will change a over steering car into a under steer pretty quick.  No experience with a big car like a Gal, but in smaller cars when you get into the 1~1 1/8 bars up front you really need to look at 1/2~5/8 rears to keep things balanced.  Just FYI.
