FE Power Forums => FE Technical Forum => Topic started by: 338Raptor on June 15, 2020, 02:47:31 AM
I just purchased a NOS 4v iron Cammer that the previous owner modified with 10 to 1 compression and different cams. Other than some inter coatings, better carb, and electronic ignition the rest is stock. The motor currently is setup with 30 degrees total timing (which seems a little low) And the best I can tell from his notes the cams are advanced 2 and 4 degrees. His reason for these changes was to make the motor more streetable and pump gas friendly. I’ll send the cam card in the next post. I believe the cams he used are very close to stock.
My question is how much power do you guys think the motor is making?
No luck uploading a picture of the cam card.
Crane grind: CCR-570
Intake .570 lift at valve
Exhaust .570 lift at valve
Open. Close. Max lift. Dur.
Int @.021 36 btdc 74 abdc. 290
Exh @.021. 84 bbdc 26 atdc. 290
Int. @.066 15 btdc 53 abdc. 109 atdc 248
Exh @.066 63 bbdc 5 atdc. 119 btdc 248
Remarks: the above reflects zero lash
My engine was dynoed in a very similar configuration, although it does have a 4.00” stroke crank giving 452 ci, and my cams are 252 @0.050” and 0.582” lift. It has 10.3 to 1 static compression, and was run with a 750dp and 29 degrees total timing to suit 93 octane pump fuel. It made 553hp at 6300rpm. The heads are early iron heads, and pretty close to stock.
I have since changed the intake manifold to a Dove 8V Tunnel Wedge and a pair of 780vs Holleys. I haven’t had it dynoed in this configuration, but it certainly feels a lot stronger to my butt-o-meter. If you read any of the test literature from when these engines were released, they all state the 4V intake manifold suffered from poor distribution between cylinders. The factory 8V intake increased the hp by around 40hp.
I think 550 HP is probably about right. 30 degrees total advance is about right too, the most I've had to go on one of those engines is 32 total. They are prone to detonation with more ignition advance.
Ford's crate engines were stated to make roughly 550 hp and 490 lb-ft for the single carb, 620 hp and 510 lb-ft for the dual carb. This comes from their SAE paper on the development of the SOHC.
Those OEM SOHC engines were higher compression than the original poster's engine, I believe.
If the OEM engine had 12 to 1 compression and made 550hp and my engine now has 10 to 1 with cams that are close to stock. I’m guessing I have a reduction of 6-7%.
So maybe it makes 500hp now?
Agree or disagree??
I guess I need to put it on a chassis dyno and quit guessing.
My original iron SOHC (unmolested) worked out to about 10.7:1 compression ratio with the original TRW pistons.
There's a bit of misconception that all of the series-produced SOHC engines had 12:1 compression. From what I have learned, the early examples did indeed run a number like that. The later 1966 "Street" series Cammer engines had a more pump gas-friendly compression ratio. My engine bears this out...
Agree or disagree??
