FE Power Forums => Non-FE Discussion Forum => Topic started by: Cyclone Joe on June 07, 2020, 04:25:21 PM
Title: Venting....2017 Ford Fusion Sport - blown engine
Post by: Cyclone Joe on June 07, 2020, 04:25:21 PM
I wish it was the cool kind of blown engine with big wide cogged belts or a big turbo sticking through the roof.  But no, with about 75,000 miles on the clock, the engine is checking out.  According to Ford, the heads have a design defect in them so the head gaskets are slowly going which is why I get a random check-engine and cylinder mis-fire.  TSB's are out there for the repair, and other vehicles with the same engine have been recalled - but not the lowly Fusion Sport.    Feedback from Ford Corporate was we can take, $1,000 off the $8,500 dollar bill to replace both heads and all the gaskets (25 hour job) but not much else.
I have to say I'm torn - I know its out of warranty but its a known design flaw that forced recalls on other vehicles with the 2.7L.  Really gives me pause whether or not to buy another Ford.  All services were done by Ford as well.  My old fusion went over 210,000 miles and never missed a beat.
I guess buyer beware next time to spring for the extended warranty.  Its too bad too - this car was an absolute dream to drive.
Joe
Title: Re: 2017 Ford Fusion Sport - blown engine
Post by: machoneman on June 07, 2020, 04:45:23 PM
https://www.carcomplaints.com/Ford/Fusion/2017/engine/engine.shtml
Post by: Cyclone Joe on June 07, 2020, 05:25:10 PM
Exactly, its not like there aren't complaints to warrant the recall.  Pure guess - they didnt build many of them so as a result they probably can justify not recalling them.
Title: Re: Venting....2017 Ford Fusion Sport - blown engine
Post by: winr1 on June 07, 2020, 07:45:18 PM
What is the reason the heads have to be replaced and not repaired ??
Ricky.
Post by: Rory428 on June 07, 2020, 09:57:44 PM
I agree that this sucks, and I believe that a known problem should looked into, and adressed. But after recently retiring from over 2 decades at a Toyota dealership, don`t think that its just a Ford issue. I always found it rather strange that if any of the "big 3" had a major issue, the TV stations,Newspapers and car magazines were all over it , yet it seems that many of the non American brands seem to be immune from bad press for the most part.When people hear that I own a Ford V10 truck, I often get the old" how often have the spark plugs blown out, broke inside the head, or stripped the threads out in the heads" (Zero on any of these "common problems"), yet you rarely hear about some Toyotas having the head bolt threads in the block pull out, excessive oil consumption on certain 4 cylinder models, major sludge issues on some V6s, major frame rust out issues on fairly new trucks, premature water pump failures, electrical wiring that rats find too tasty to resist, among many other things, you have to wonder. And don`t even get me started on my 10 years at Hyundai before that !
Post by: JamesonRacing on June 07, 2020, 11:09:35 PM
Man that sucks.  The 2.0L Ecoboost in my 2014 Fusion is loads of fun and has never missed a beat.  I was keeping an eye out for a deal on a 2.7L Sport.  Maybe I should set my sights on something else.
Post by: Diogenes on June 08, 2020, 04:37:59 AM
Oh yeah, the 1ZZFE engine in my parents old car--it racked up some miles and never left them stranded, but it burned oil horribly.
Post by: chilly460 on June 08, 2020, 08:57:34 AM
I realize this stuff happens to all makes, but I hate reading stuff like this.  It absolutely contributes to the perception that Domestic vehicles are sub-par.
Post by: Falcon67 on June 08, 2020, 09:29:11 AM
I don't buy any new car without 6 yr/100K.  Period.  Stuff happens.  If you doubt that LOL, our new 2020 F-350 7.3L just got a new engine at 1700 miles.  Engine assembly problem, potential piston cooler mount defect.  Not an extended warranty thing, but now I drive a brand new truck on it's 2nd engine, a brand new design that took the dealer a week to do because no one  - mechanics, or other service types - have ever taken a wrench to this deal.  The senior tech thought if it was like most others, 2 days and out.  Ended up 8 days plus one trip on a rollback after hand off + one more day = 9 total.
Post by: Thumperbird on June 08, 2020, 10:11:26 AM
Don't get me started on my 94 Taurus wagon that had bad head gaskets, cracked trans. diaphragm, ac compressor failure, window regulator corrosion, and major rear end alignment issues all in before or just after the 60k warranty.  Nice car at the time and drove well, piece of you know what otherwise.
Have gone through a couple of Ford trucks since, better but still no great deal, 2000 f150 was a rust bucket in short time and the 1998 Expedition had head gasket issues.  Both trucks had major frame or suspension member rust after a dozen years or so which I do not consider acceptable.
Sorry but my Honda's and Acura's are superior.  Honda's V6 is bulletproof.
Post by: My427stang on June 08, 2020, 10:17:35 AM
If it's off warranty I think I would try cutting the heads, new gaskets, and bolts if required, would even be nicer if ARP makes a stud.  You'd likely never have to touch it again.  Then decide later about flipping it or just drive off.
ON EDIT: After looking at the complaints, I guess the question would be whether its a head gasket or cracked block. Does anyone have truth data on what is failing?  I'd would assume it's worse than a head gasket or Ford would repair rather than replace
Post by: badcatt on June 08, 2020, 10:31:56 AM
I had a 2015 Focus SE I bought before I retired, I ordered it loaded up with extras. I was assured the multi Clutch transmission problems had been taken care of. They were not. I had in in for reprogramming a couple times, but had gotten use to shifting it manually. I don't have it any more. But not by my actions, it got rear ended and pushed in to the back of a Dakota. I think I did better on the insurance settlement then if I had tried to sell it.
Post by: machoneman on June 08, 2020, 10:35:10 AM
My 2006 Nissan Altima purchased new ended up with a host of engineering and quality issues. Having owned a lot of cars (20+?) over the years, it was the absolute worst! The P/S return line was way too close to the 4-cylinder engine's exhaust manifold and it cooked over time the fluid with a total loss of steering! Hairy the first time it appeared. The dealer said it needed a new R&P assembly, over $800 but Nissan would cover the labor. Smellled a rat. I ended up sucking out the fluid (near 80%) and added new stuff, sucked that out a few times and eventually the fluid was 100% new. Problem solved for about $25 worth of fluid.
Oh, and don't get me started on the badly rusted floors pans (another common issue, the cowl water seeped down between the pressed steel floor pans) the tiny rear brake calipers and pads (did the rears myself twice before the fronts even got down to say 25% left!) the spidery look to the inside rear view mirror (making it look like a 100 year old bedroom mirror, in a car 5 years old!), the badly faded paint on the tops of both outside mirrors and more. Never another Nissan, ever!
Btw, next daily driver was a Kia Optima and I gotta say, it was just about the best, most trouble-free car I have ever owned. Hated to trade it in for the Audi but I had too many other Mustangs in the garage. Shoulda' kept it anyway............
Post by: Cyclone Joe on June 08, 2020, 05:56:04 PM
Ross,
It appears to be the head having a design defect allowing the the pressure and thermal cycles to 'work' the head gasket until it fails adjacent to one of the cooling pass-throughs.  The new heads are over half the cost of the job.
Post by: Cyclone Joe on June 08, 2020, 11:41:28 PM
And to Rory, the reason I'll never buy another Toyota was due to the head gasket issue in my 1997 Toyota Tacoma 2WD that had the ominous 3.4L 5VZFE V-6.  At least Toyota had the decency to replace both head gaskets under warranty. The timing belt bolt/washer combo was a peach to figure out without the internet though!  Maybe Im just too picky!
V/R
Joe
Post by: My427stang on June 09, 2020, 07:22:30 AM
Ross,
Gotcha, I would think Ford would have tried to exhaust cheaper methods than replace the heads, but I think back to 6.0 diesels.  They would lift the heads with boost, but adding head studs would let them live even when asked to do crazy things.  Though maybe you could cheat there and get off cheaper if ARP made a stud that would work
Post by: Heo on June 09, 2020, 12:23:00 PM
Ross,
Maybe if head is clamped down harder with studs the head would not be able to work the gasket
Post by: RustyCrankshaft on June 09, 2020, 04:52:12 PM
Ross,
The 6.0 head gasket failures were mostly due to the EGR system, not boost. Stock head bolts are will hold to around 450 rwhp and 45lbs of boost if the tune is good.
Every manufacturer has problems, but overall Ford does pretty good as a company. Their warranty return rate is pretty low. I've had stuff from Ford that was crap and others that have been fine. My 2001 Ranger 4.0 SOHC now has 291k miles and it's had 2 EGR valves before that got turned off and a month ago I finally had to put new valve cover orings in it. Alternatively I had a Toyota truck that had to have the FRAME replaced under warranty because they break in half. For whatever reason, brand loyalty, media coverage, etc. you don't hear too much about the import failures than you do domestic.
It just sucks more when it's your thing that is the defective one! Been there and done that. But I'd buy another Toyota truck if I found one I liked even after my warranty frame replacement. A sample size of 1 that I've owned and failed is just that, 1. I could own a 100 more and maybe never see the problem again. (Ok, well with my luck 99 out of 100 would fail, but my bad luck aside you get the point).
Post by: TimeWarpF100 on June 18, 2020, 09:48:37 AM
Joe
Bummer about the 2.7 I almost bought a Fusion Sport when they first came out.  I have torn down & messed with the 2.7.
For that much $$ why not just get a complete replacement engine. Looking online I found one with 11,588 miles for only 2075.00 here in phoenix. Keep yours for parts/spare. Doesn't pay to spend that much money on a 75k mile engine.
I would push a little harder on replacement especially when Ford is aware of a issue.
Post by: TimeWarpF100 on June 18, 2020, 09:52:05 AM
H & H Boot Hill located in Denver shows a 7000 mile engine for 1699.00 and am sure its negotiable.
Many many engines out there with under 10k miles for 2k or less.
Post by: TimeWarpF100 on June 18, 2020, 10:01:23 AM
I have torn these engines down. It takes a BUNCH of time to tear down then put back together. Very complex & just the gaskets are BIG $$ It's a bunch of labor to pull the heads simply not worth it. Reason it is 25 hours for the head replacement or whatever was quoted. Pull and replace is only way to fly. I found probably over a 100 low mile engines out there.
Not like building a FE . .
Post by: WConley on June 18, 2020, 10:15:04 AM
+1.  If it was my car, I'd do that in a heartbeat.  Yes the engine swap is some work, but it's do-able with normal tools.  I've torn into several modern engines and it's a giant pain!
Post by: My427stang on June 19, 2020, 07:54:35 AM
So I have been in almost anything you can think of, but not of course one of these...that being said, how can you justify swapping another for potentially the same failure?  Even 25 hrs flat rate to repair is likely 2 days work humping, and you are running, especially if there is an updated head design or other potential fix.
Is there another year or updated head design that he could ID before purchasing a low mile engine?  Otherwise seems like just buying time for the same failure, with a day or two worth of work, to include prepping the JY engine for swap
Post by: TimeWarpF100 on June 21, 2020, 05:58:20 PM
The justification is spending less than 2k and a day of time for a low mile engine or paying the dealer 7k to fix the old higher mile engine.
Labor is 25 hours to replace the head where as to replace entire engine can be done in a day easily with basic hand tools.
If it were a f150 then the cab can be pulled in under 2hrs then swap engine in a few more.
No brainer. 2k and a day or 7500 and  . . .  Or, junk the otherwise good car.  2k engine and sell it would be good way to keep it from happening again.
I know of a bunch of 2.7 with zero issues. The Fusion Sport was a very limited deal different block than the truck
Post by: Cyclone Joe on June 21, 2020, 11:11:14 PM
Ended up trading it in at a Porsche Dealer for $11k.
Its their problem now :)
Joe
