FE Power Forums => Non-FE Discussion Forum => Topic started by: winr1 on May 07, 2020, 11:50:37 PM
Title: Houston/Galveston area BUC-EE'S gas stations sells ethanol free gas ??
Post by: winr1 on May 07, 2020, 11:50:37 PM
I have had several folks allow BUC-EE's gas stations sell ethanol free gas
They were in counties only and not in any city limit
Have called more than a few and the employees have no clue as to what I am asking them
Any know before I start driving around to see personally ??
Ricky.
Title: Re: Houston/Galveston area BUC-EE'S gas stations sells ethanol free gas ??
Post by: cattleFEeder on May 08, 2020, 06:31:28 AM
Try this. https://www.pure-gas.org/extensions/maps.jsp?statecode=TX
Post by: HarleyJack17 on May 08, 2020, 07:59:32 AM
May not be of help, but if your have Murphy gas stations, their premium is supposed to be E-Free.
Get some and do a water test......easy to check before a complete fill up.
Post by: Falcon67 on May 08, 2020, 10:16:47 AM
I'd be a little surprised being anywhere close to one of our EPA non-attainment areas.  Personally, chasing "ethanol free" gas is IMHO a waste of time.  Pump fuel of any sort is not readily storable.  And I have no issues with any of it in my equipment.  We're a long way here from any EPA area and you can't find any ethanol free anyway.  And not driving to Cross Plains, Brownwood or San Angelo to fetch it.
Most Buc-ees stations are huge, so I could see them having a couple of pumps set aside for oddball stuff.  Not here, no mondo stations like Racetrac, etc.
Post by: Falcon67 on May 08, 2020, 10:21:55 AM
FYI for those not familiar with "Buc-ees"
"In 2012, Buc-ee's opened its largest travel center in New Braunfels, Texas, on Interstate 35. The New Braunfels location is the largest convenience store in the world at 68,000 square feet. The store features 120 fueling positions, 83 toilets, 31 cash registers, 4 Icee machines, and 80 fountain dispensers."
Most of the other ones ain't small.
Post by: cammerfe on May 08, 2020, 11:47:40 AM
I've switched to looking for those who offer E-85. When things get serious, I plan to have a tune for pump E-85, another tune for race E-85 and the yet another for methanol. The degree of boost will be set accordingly. There will always be a cell for methanol for when the spray is activated. Boost = spray as a chemical intercooler.
Post by: Falcon67 on May 08, 2020, 03:08:36 PM
No E-85 here either unless you buy a drum of Sunoco or VP.
Post by: RustyCrankshaft on May 08, 2020, 06:06:19 PM
Most Cenex stations premium (92 or 94 depending on regon) is ethanol free.
Post by: winr1 on May 09, 2020, 01:34:00 AM
Thanks guys :-)
I let the 600 Holley on the 352 in my 65 F100 sit over 2 months twice in 3 years
Had to soak it, run wire through all the orifices, and rebuild it cause the pump needle gunked up
The bowls/jets were full on gunk.. I drained the fuel tank as well... ran like crap after carb rebuild
Fuel smelled like a Bramah's hiney
Thought I would try ethanol fuel and see if there is a difference
Firing the mill up at least 3 times a month and getting it to 160 degrees is what I normally do
Ricky.
Post by: Bolted to Floor on May 09, 2020, 08:58:54 AM
About a year ago I saw Ethanol free gas at the Bucc-ee's in Katy. I haven't stopped through there in a while to know if its something they still offer.
Post by: hwoods on May 13, 2020, 05:02:00 PM
Buc Cees in Waller Tx sells ethanol free gasoline.  Expect to pay about $1/gallon more than gas with Ethanol added
Post by: winr1 on May 14, 2020, 12:19:46 AM
Thanks guys !!
Ricky.
