FE Power Forums => FE Technical Forum => Topic started by: 410bruce on February 24, 2020, 08:27:54 AM
Hey guys. At what point are the base, non-reinforced main cylinder blocks considered not advisable to use? Street or race use.
Thanks.
When they split in half.....LOL
There's really not a number that you can put on a block as to when it will fail. It depends on the rpm, horsepower, etc., etc. Some of them may live at 700 hp, some may split at 600.
Cool. Thanks Brent. :)
I have a couple 428 blocks that are cracked up the mains. One was raced, but I know it wasn’t making anywhere near 600hp, the other I don’t know the history of, but no evidence it was a high horsepower engine either. Both have the three finger main webs.
(https://i.postimg.cc/T3GwPmGb/175-BC5-CB-242-C-4-BDA-B705-EA1-A693-CCE60.jpg) (https://postimg.cc/jLgKgDDq)
Wow! I wonder what would cause that? Is that repairable?
Truth for all stock blocks IMHO. I've seen 302 blocks go 2~3 seasons with 500+ HP N/A and a 150 shot every pass and seen same blocks go 4 passes at under 500 HP and then fall apart. Same like rear ends LOL - a guy I know that raced a Cougar - 351W, low 11's - ran wheels up every pass on an 8" rear pig with 28 spline axles. 3rd year he finally spit the pinion out. Most of the Ford people I know that race are using aftermarket blocks. You just never know. The spare 302 makes around 300 ish, I put that one together in 1995. I had a 351C that went 2 seasons and split 5 cylinder walls plus exhibited major cap walk, the 351C in the Falcon has been raced since 2006, has 3000+ rounds on it. Like a Timex watch LOL. [ Immediately runs around knocking on every piece of wood in the office]
