FE Power Forums => FE Technical Forum => Topic started by: 6667fan on January 27, 2020, 09:26:42 PM
Title: Help i.d. these heads 406 390 ?
Post by: 6667fan on January 27, 2020, 09:26:42 PM
C3AE-C, casting dates of mid December 62 and early January 63. Spring cups. Like to think they are 406 6V heads but they cc at 67. What say ye?
Thanks,
JB
Title: Re: Help i.d. these heads 406 390 ?
Post by: BH107 on January 28, 2020, 07:41:46 AM
What size exhaust valves? They should be 406 heads with those dates and spring cups and maybe just in the high end of tolerance for chamber size.
Post by: chris401 on January 28, 2020, 10:28:35 AM
The heads could have been machined for spring cups latter or be on the big side like BH107 said.
Post by: 6667fan on January 28, 2020, 10:47:52 AM
The owner has measured the exhaust valves at 1.6 so that is right for a 406. What if someone did machine for the cups later? Unless the springs/cups are removed and there is a tell tale difference between Ford's machining and aftermarket machining how are we to be certain? 56 cc as cast to 67 cc seems like a big difference.
JB
Post by: machoneman on January 28, 2020, 11:06:01 AM
http://www.mustangtek.com/heads/C3AE-6090-C.html
http://www.mustangtek.com/heads/Heads.html
Post by: chris401 on January 28, 2020, 07:31:09 PM
56.4 seems very small for that combustion chamber shape. The 390 set C heads I had were 67 cc. The seemingly cramped C0AE-D head has about 60cc.
Post by: 6667fan on January 29, 2020, 08:51:42 AM
I had visited Mustang Tek myself. The 67 cc that lines up with 390 heads is making it difficult to jump up and call my friends heads the 406 version of the C head.
JB
Post by: Joe-JDC on January 29, 2020, 11:40:46 AM
Going by faded memory here, but the 406 heads I have seen in the long ago past, had seat cups like the 289 hp, actually cast into the heads, not milled into them.  I may be wrong, but that is how I remember them.  Joe-JDC
Post by: 6667fan on February 15, 2020, 01:42:18 PM
Builder at machine shop where heads are removed a valve today so we could see the surface. This machining does not look like Ford work to me. What say ye?
Also, the intake valve measured 2.025
Thanks,
JB
Post by: 67428GT500 on February 19, 2020, 01:57:49 PM
The 406 heads are C2SE-C
Post by: 6667fan on February 19, 2020, 07:18:03 PM
Hi Keith, there are definitely C2 406 heads but there are also some C3-C heads. That’s where it gets tricky because there are C3-C 390 heads in a very similar time period. I’m trying to help a friend figure out which ones he has.
JB
Post by: 67428GT500 on February 20, 2020, 04:15:56 AM
I had them years ago. C2SE-6090-C They had spring seats like the 427 heads. They were off a tri-power 406. they were 64CC chambers
I hope that's helpful.
Post by: 6667fan on February 20, 2020, 08:59:52 AM
Keith,
Check the pic above in this thread that shows the head surface beneath the spring. Did the heads you had have a cast in cup for the springs a la the 289 HiPo heads? Several old threads have alluded to the 406 6V  head having the machined in or cast in cups but I have not seen any pictures of one.
Thanks,
JB
Post by: chris401 on February 20, 2020, 11:21:54 AM
Thanks,
JB
The 67 cc High Altitude 390 C3AE-C I had looked like that. I never saw the C3AE-C 406 version off the car.
Post by: 67428GT500 on February 20, 2020, 12:05:53 PM
406 heads are C2SE or C3SE. I tried to post picture earlier. I have the same spring cups as you do. The head was machined for them. from the factory. Let me see if I can convert the files so I can attach them.
Post by: 6667fan on February 21, 2020, 01:03:18 PM
Figured I would post a few pics of different heads to show some apparent differences between cast and machined spring pockets. I still don’t know if the heads are 390 or 406. They match what Chris said, ( Denver heads).
Thanks,
JB
Post by: 67428GT500 on February 23, 2020, 07:10:20 PM
The 406 C2SE/ C3SE heads should not have a seat "cut" into the head. They use a cup like the 427 .  In they are cut into the spring seat they're not OE seats. Also something to consider is the only heads listed with cup seats was the 6V heads.
Post by: 67428GT500 on February 23, 2020, 08:12:55 PM
I have pictures I can send to you if you want to PM me an Email address. They are of the C2SE-C 406 heads. 64CC chamber.
Post by: BH107 on February 23, 2020, 10:05:32 PM
Do you have a good picture of the chambers?
Post by: 67428GT500 on February 24, 2020, 12:31:53 AM
I sure do!
Post by: 6667fan on February 24, 2020, 01:08:57 PM
Keith, my email address is jwysocki@charter.net
The machinist at the shop where the heads are feels something was taken off the deck. Measuring off head bolt holes to establish deck height was inconclusive.
Might be awhile before I get back there to get more pics. At 67 cc with a skimmed deck how could they be '63 6V heads?
Thanks,
JB
Post by: 67428GT500 on February 24, 2020, 03:40:32 PM
You have E-mail. The pictures should help you out. However, the engineering numbers on the castings only show two possibilities.
Post by: 67428GT500 on February 25, 2020, 02:31:50 PM
JB: Did the Emailed pictures help you with identification at all?
        -Keith
