FE Power Forums => FE Technical Forum => Topic started by: Yellow Truck on December 04, 2019, 04:52:18 PM
Title: Benefits of using a start retard and pinning the distributor?
Post by: Yellow Truck on December 04, 2019, 04:52:18 PM
Percy, my neighbour and engine building/carb tuning buddy, suggested I consider replacing the MDS 6AL box with a Pertronix Digital  HP box and pinning the distributor at max timing.
On the one hand having an easier start is nice, I don't run the vacuum retard now and timing is set at 26 initial and 34 total. Getting initial down under 20 would probably help the starter last, although it doesn't seem to struggle - but I do occasionally hear it kick back during cranking.
My question is, what is the benefit of running the engine at total (i.e. max) timing all the time except on start up? Percy did say that I may get few benefits other than easier starting (and the claimed better spark characteristics of the Petronix box) since I already run fairly big initial timing.
Title: Re: Benefits of using a start retard and pinning the distributor?
Post by: GerryP on December 04, 2019, 06:06:05 PM
The engineers who work in the powertrain divisions of all the manufacturers are complete idiots.  I mean profoundly stupid.  They -and I mean all of them- went through the trouble of using centrifugal advance and vacuum advance mechanisms for nearly every vehicle that rolled off the assembly line.  And, the accountants...don't even get me started on them, those imbeciles!  The they could have saved the company money by not paying for a bunch of useless parts in the distributor.  Think of how much they could have saved if the ditched the centrifugal and vacuum advance.  Maybe not a lot for an individual car, but over millions of cars,  why, you could buy a country for what they wasted.
Seriously, this is a bit tongue-in-cheek, so take it for what it's worth.  If you are building a dedicated drag or track car, then by all means, lock out the distributor.  If you're not doing that, then there are clear advantages to using both centrifugal and vacuum advance.  I will say this on vacuum advance, though;  The higher your static compression the less value there is in vacuum advance.  Once you're over 11:1, you don't need vacuum advance.
There is one other scenario where you would lock out the distributor and that is where a computer is controlling all timing events.
Post by: pbf777 on December 04, 2019, 08:12:01 PM
...............................and pinning the distributor at max timing.
............................... - but I do occasionally hear it kick back during cranking.
     Having the distributor timing advance function "locked-out" is fine for engines that when in use remain at an R.P.M. that would/should be experiencing full advance anyway; as if only this reduces the possibility of experiencing component or function  failure of such system in competition.   But in the more dynamic R.P.M. operating range required in most "street" operation if this is practiced, one may experience greater difficulties in the starter motor operation (if not retarded as you mentioned), and particularly in manual transmission applications in the transitional throttle applications implemented during shifting and at lower to mid range R.P.M's at moderate to heavy loads experience detonation ("engine knock") which is best avoided.        ;)
     Scott.
Post by: 428 GALAXIE on December 04, 2019, 11:23:04 PM
I would assume spark curve would be in the box?
With start retard.??
Why not.
Post by: mikeelikee on December 05, 2019, 10:04:41 AM
Bingo!!
Post by: Falcon67 on December 05, 2019, 10:08:21 AM
Every "street/strip" engine I use here has locked timing.  The Mallory box has a 10 degree retard, so cranking advance is 26 on the 302 and 28 on the 351C.  The 351C runs 10.5:1 compression.  I only use PMGR starters and have zero starting issues.  Driving at the track in the lanes I'll start it 4~5 times or more when at operating temp.  Carbs are easier to tune and set, car is more responsive, timing easy to set - just one number.  If you run a performance converter with an automatic, who needs a "timing curve" because you'll be past the "all in by 2500" range before you get 30' out.  The dragster engine has no retard, is set at 26, 11.8:1 and starts easy.
Post by: pbf777 on December 05, 2019, 10:49:09 AM
     C'mon,.......... for "period correct" function: one would place a spacer under the distributor hold-down bolt so as when the bolt is tightened it would lock the hold-down fork rigidly, retaining the distributor body vertically, but permit rotation (don't  forget the grease); then establish "stops", such as weld beads to the distributors' locating rim, shaped/ground to act against the hold-down fork, permitting the desired timing sums of "START" & "RUN"; then fabricate a bracket to the two screw holes for the vacuum dashpot (removed if equipped & don't forget to lock-down the breaker plate if applicable), and cable stay bracket to the intake manifold bolt at the front, for attachment of a push/pull choke cable routed to the interior dash board.  There needs to be sufficient "drag" on the cable or the use of the "ratchet" type, to resist the rotational reaction in operation of the distributor body, and perhaps an added tension spring in the linkage may be required to dampen this effect.
     This is how we dun-it before the "BOX" come along.      ::)
     Scott.
Post by: Yellow Truck on December 05, 2019, 12:45:22 PM
Why not.
The Petronix box has start retard, but it doesn't provide a computer controlled spark curve. I am surprised at that, but it relates to the utility of having initial vs full timing. I haven't read much on the purpose of a timing curve, only the problems of having a bad one. If the purpose is better fuel economy or such, then I don't care and would go with a pinned distributor and a start retard. If it is to make starting easier, ditto.
If delaying full timing makes the engine run better at idle to 2,500 RPM, that would make me reluctant to eliminate it. For what it is worth, if I had it to do over I would not give a dime to MDS. Aside from the multiple failures with the "ready to run" distributor, their customer support was like dealing with inmates in a lunatic asylum. I would be strongly inclined to run the Petronix box and even if I didn't pin the distributor I'd add a small start retard to get start timing down around 18 degrees. The starter is handling 26 degrees but if I had it I'd use the start retard to make it easier on the original Ford starter.
Post by: Jim Comet on December 05, 2019, 01:06:41 PM
I have been running locked out timing on my high 10 second Comet with the Pertronix digital HP and and very happy with it. I also wish the timing curve was programmable. The 2 step and start retard along with the rev limiters all have worked flawlessly through my 1st year. Jim
Post by: Yellow Truck on December 05, 2019, 01:28:10 PM
I was puzzled that it didn't offer a programmable timing curve, but it may be because there is really no value if you have start retard. I don't really have enough experience with timing to really understand how it affects performance. What I do know is that at idle my engine ran better at 27 degrees than it did at 18 or 20, but it also didn't run any worse at idle all the way up to 40 degrees.
Hopefully one of the usual suspects with lots of experience and insight can tell us why initial timing is used. Percy, my neighbour and tuning buddy has a lot of experience building sprint cars, and they all run locked in timing. Now they are all push started, and run pretty much flat out all the time, so initial timing is irrelevant.
Post by: Jim Comet on December 06, 2019, 07:25:48 AM
I should have added that I have a 5000 stall converter, so the motor flashes right past the rpm range where the timing curve takes place. Jim
Post by: BattlestarGalactic on December 06, 2019, 08:13:22 AM
Basically as long as it doesn't knock/ping under load in lower RPM you can run as much timing as it will take.  That is the only drawback to locked timing.  In a daily driver, you can get into trouble if you lug it too much at a low rpm and it rattles.
Post by: Falcon67 on December 06, 2019, 12:45:17 PM
Very true - as with any configuration parameter, it's completely application and total system dependent.  Big Galaxy, 390, 11" converter, 3.23 gear - ya, you'd likely benefit from timing control.   Light car, 10" performance converter, 3.70 up gear - maybe not.
FWIW - I haven't had any issues with MSD parts.  I use their pickups instead of Ford type if I run a Duraspark type distributor.  The ignition in the door car is a Mallory 685 with a lot of built in functions.  I went with that one because it was cheaper and had more functionality (retards, window switching, dial back for nitrous applications, etc) than an MSD 6 or 7 with all the extra stuff hung on it.  Dragster runs a 7AL-2 and a MSD crank trigger - no issues with either.
Post by: Falcon67 on December 06, 2019, 01:58:23 PM
Here - something else to consider
http://4secondsflat.com/Daytona-Sensors%20Main.htm
http://4secondsflat.com/CD1-MSD-Crane%20Comparison.htm
Post by: Jim Comet on December 06, 2019, 02:37:33 PM
The last thing I will add is, if you call Pertronix you may be able to get one of their Digital Mobile HP units like I have. The benefit to this is all functions are controlled with your smart phone. It also reads out a live tach and voltage readings. It was $300 bucks which I thought was a good deal for the features it has. Jim
Post by: Yellow Truck on December 06, 2019, 02:39:27 PM
Chris - what I'm really looking for is a good explanation of how timing really needs to behave when compared to engine load and speed characteristics.
I recently read an article that claimed you need more advance at cruise when the engine is essentially running lean (high vacuum and mostly closed throttle relying on the idle circuit for fuel) than you do at WOT where you are getting lots of fuel and flame front moves more quickly.
It really got me thinking that I don't really know much about how spark timing, fuel density, engine speed and vacuum all interact.
Post by: cjshaker on December 06, 2019, 02:52:17 PM
I wish I knew what has caused me to replace 4 MSD pickups in as many years. Box wired directly to the battery with a cut-off switch, pickup wires shielded and routed away from any heat or electrical interference areas. It always comes soon after I notice a momentary blip on my Autometer tach, where the needle drops for a split second like there was a single misfire. Whenever I see that happen, I know it's coming soon. Last time was after the FE Reunion; car ran perfect at the Reunion, but I noticed a blip on the return road on one of the last runs I made. Next time the car was used was at a UMTR race just 2 weeks later, went to fire it up to pull it out of the trailer, and nothing. Same scenario every time. It's getting really old. I have two MSD billet distributors, both do the same thing, although the distributor should have no bearing on the pickup surviving. I have to carry a spare distributor AND a second spare pickup (a backup to my backup ::))
Not trying to derail the thread...
Post by: Yellow Truck on December 06, 2019, 02:58:12 PM
I never got more than 15 minutes of run time on my MSD billet distributor, but what made me absolutely give up was the insane conversations I had with their support people. First the told me it was bad, but they couldn't send it back because the shaft had been drilled for the gear, and they didn't have any shafts. When I asked them to just send me a new one, they told me they didn't have any new ones in stock. Then suddenly there was nothing wrong with the one I sent in, it had never failed, and they sent it back. It ran for 4 minutes before it failed. I sent it back and I had another series of insane conversations before I gave up and returned it.
Post by: 6667fan on December 09, 2019, 12:29:18 PM
If you keep the MSD you have the option of decreasing the initial and getting back to the total you want via replacing the bushings in the distributor. If you bought it new there would be included a small bag with springs and bushings. Some engines/battery combos can struggle with 26 degrees of initial timing when it comes to hot starting. I run 18/14 in my combo but have very good heads which allow for less total than some hi-po FEs.
JB
Post by: Yellow Truck on December 09, 2019, 12:57:29 PM
JB
I hear you. I returned the MSD long ago. Only being able to drive a couple of miles on each distributor was a little inefficient. The Ford Duraspark provide similar options. I was able to get the initial it liked (around 26) and total of 34. We had to modify the plate a little to stop it at 34 because with initial of 26 it put total out around 39.
The question I'm really asking is - what is the use of initial vs total in getting optimal engine performance? The idea of pinning the distributor to the total timing and adding start retard is what got me thinking, and made me realize I didn't really understand what the engine needs under different load/rpm conditions.
Post by: 351crules on December 09, 2019, 02:07:01 PM
i lock out the distributor out as well....
Post by: GerryP on December 09, 2019, 02:24:56 PM
You are at the point where you need to just go ahead and do it.  See what happens.  If the engine is not happy, then put it back to where it was.  That is how tuning works.  Simple, no?
Post by: Yellow Truck on December 09, 2019, 07:47:52 PM
I would say yes and no. Since some things are basically free, and some require buying expensive parts, the former are the yes, the latter are the no.
Post by: frnkeore on December 09, 2019, 08:04:58 PM
I also like to lock the ignition at total advance. I've near understood why you need any "curve" on the ignition, in a race application. They don't run worth a darn at lower speeds, anyway.
If you have enough overlap on the cam, it will also turn over and start easy, if not you need more cam ;)
Post by: GerryP on December 09, 2019, 08:07:50 PM
...I've near understood why you need any "curve" on the ignition, in a race application. They don't run worth a darn at lower speeds, anyway.
You don't.  It's a foolish waste of time to set one up.
Post by: Yellow Truck on December 09, 2019, 09:31:51 PM
Just for context, I am looking at it for a 4WD pickup truck with a 445 with 234 and 240 durations at .050. Clearly not a racing application.
Post by: plovett on December 10, 2019, 06:22:52 AM
Oops.  Wrong thread.
