FE Power Forums => FE Technical Forum => Topic started by: My427stang on September 27, 2019, 05:43:15 AM
I was forced to run another color on the hyd roller 461, but hoping to find a high quality black small distributor cap.
NAPA, O'reilley, Advance, Autozone all have blue or gray brass terminals, or really cheesy black with aluminum. Anyone know if a good black one is out there?
#948220 Taylor is a nice quality cap, but is a "maroon" color. I believe a person could paint it if needed....................
Here is one https://www.summitracing.com/parts/sdk-b7a-12106-a/overview/make/ford.
I got 1 from my local napa in july that was black with brass but maybe it was old stock.
Edit for new online search https://www.napaonline.com/en/search/ignition-electrical-lighting/ignition-parts-distributors-distributor-parts/auto-parts/mercury/cyclone/1969?q=N%3D2500001%2B2600101%2B5004600%2B200460370%2B10196900%2B404606100%2B599999900%2B50450600%2B50499900%2B2805253%26Ns%3DP_CatScatSequence1_1&referer=PLP&leftNav=leftNav
If you want to run something like newer 8mm wires, you'll need an male terminal cap. Either IH 304 V8 part. Fits Prestolite/Autolite distributor base (same as Duraspark, etc.)
https://www.summitracing.com/parts/smp-al482
Pertronix makes a stock look Ford Distributor, may be able to purchase just cap from them/Summitt/Jegs
I have 10MM Taylor wires plugged into it
Ross, I’ve been using a lot of Standard Motor Products myself. JMHO
rock auto as them
Standard motor products and NPD has a black one with the 1 on it that is concours and made by the OE manufacturer. It's got nice heavy contacts in it. The last Standard Ignition products cap I bought was light blue.
-Keith
msd makes one. i hate that red crap
This is what I bought. High quality, brass contacts, gloss black and made in the USA.
https://www.summitracing.com/tx/parts/msd-5506
That's what I use on all my stock distributor stuff. Good quality and I haven't had any issues with them. I went that route because the last time I checked at my local Napa, I don't think they even offered the brass contact version anymore.
Why not use black dielectric paint ?
I bought the concours offering from NPD. The notch always seemed excessively tight and I had to bump it down with my palm to seat it.
The carbon core " Marti Autoworks" concours reproductions pull apart and the red boots tear when they are removed from the plug. Even when I use dielectric grease inside the boot in small quantity.
I bought the MSD Street Fire wires and ran them. The issue is the straight boots are a little long and the two center plug wires touch at the end of the boots.
I bought the MSD Street Fire wires and ran them. The issue is the straight boots and a little long and the two center plug wires touch at the end of the boots.
I have seen issues with repop stuff, I ended up going MSD cap. As far as the wires, I have ABSOLUTELY seen those Marti concours fall apart in my hands on a J-code 302 build. Only good enough for non-running trailer queens IMHO (and I won't build those LOL)
I generally use the Taylor Spiro-pro black 8 mm when I am hiding on a stocker, then I have a small 5/16 Dremel bit that I open up the factory plastic looms and run them like Ford would. Works well and they are all black and don't jump out at you and fit the modified looms
I don't even really consider that an option I'd entertain, not worth the time I'd have to charge to prep a cap. Worse than that for me, one scratch away from those things we used to do as kids to scratch the black paint off of colored paper to make a picture in art class LOL
X2 on the Marti concours wires. I bought a set and they pulled apart before I got them on. They are not the same quality as what came on the car originally.
