FE Power Forums => Non-FE Discussion Forum => Topic started by: mbrunson427 on September 25, 2019, 05:34:32 PM
I was driving to a job site today and noticed an F-250 Ranger on the side of the road for sale. Stopped to take a look, the closer I got the better it looked. Super super original truck, original paint, body is straight as an arrow, maroon with black interior. I called the number on the for sale sign and asked the guy if he was OK with me popping the hood, I was really hoping to find an FE under the hood. I found a 429/460 sitting it in.
I started scratching my head wondering how the truck got a 429/460 in it. Everything looked entirely original. I don't believe they ever offered that truck with a 429 option? I'm 100% sure the truck is a '69. Did somebody swap a 429 into the truck at some point and just do a really good job?
I don’t remember a 385 in the sixties trucks.
But Lincoln’s had em so.......... maybe.
Racking my old brain.
No 385 series until 78 or 79 Camper Special if I remember correctly.
460 was available in 2WD only. Not sure what the first year was from the factory, but I know for sure my 73 F350 is a factory 460 C6 truck (build sheet and vin decoded). And I've owned a 69 F250 that I think was factory but can't say for certain (the original vin tag was gone and it had a state issued replacement vin that doesn't decode to anything besides red tape and long wait lines).
Couldn't get one in a 4x4 however until well into the 80's.
The first mention of a 460 available in a Ford pickup is in the 1973 Pickup brochure. And if you look at the fine print it says not available until February 1973, so not even available at the beginning of the model year. There is no mention of 429-460 engines in the earlier pickup brochures. I double checked in the Ford Truck Parts Book, and there are no listings for the 429-460 in the 1964-1972 series of parts books. Had it been available there would have had to been parts & info. They are listed in the 1973-1979 series of parts books. The engine code in the VIN would tell the tale for sure. Here’s a picture from the back page of the 1973 Ford Pickup brochure with the standard & optional engines.
(https://i.postimg.cc/Y9JCCLVZ/43-AC686-B-BACA-425-C-89-DA-61-AED844-FC68.jpg) (https://postimg.cc/62fXHqBf)
Absolutely a swap....likely a good swap because it is an easy one using later model parts. Almost everything swaps over
In fact, I wish I would have went that way in the 80s, but now I have so many FE parts that I can't get myself to swap the truck over to a big 385 stroker LOL
Typical swap. Not sure what mounts they use, but it all fits easily. I know a fellow that had one years ago. Back in mid 90's I hurt my 428 in my '69 F100. EVERYONE told me to put a 460 in it. I stood my ground and found another FE block.
Thank you guys for the info. I did some more digging and believe it originally had a 390 and was swapped with a later 460 setup. If it had the FE in it, I think it'd be in my driveway right now. Super clean truck but am going to punt on it.
Some pictures I took:
(https://i.postimg.cc/bN8qK3y0/IMG-1558.jpg) (https://postimages.org/) (https://i.postimg.cc/8PHTDMc2/IMG-1559.jpg) (https://postimages.org/) (https://i.postimg.cc/kggq5GtB/IMG-1560.jpg) (https://postimages.org/)
Idaho plates? Likely why it is so nice. I'd like to take it home myself. ?
Curious what they are asking? Likely a good amount.
Colorado collector car plates. The guy said it spent almost all it's life in Utah, then the last few years here. Was asking $9,000 but was open to offers.
I considered it, but really don't want to deal with the 8 lug wheels, heavy rear end, and all that good stuff. 390 F100 and it would have been sold sold sold.
It would make one heck of a tow rig. :)
I don't see any downside to the swap , only positive. It sure doesn't hurt resale value.
Worked for Malone Ford in Chickasha, Okla. between 72 to 75.
We had several guys bring in their Pick ups with blown engines or worn out ones.
We installed a 429 in most of them but the 460 was the replacement engine for the f-250 f-350.
Could be this was a dealer conversion.
Greg
That heavy rear end would be a dana 60 not unlike modern Ram 1/2 ton pickups, and rumored to have less friction than a 9". You can get a cheap battery operated impact tool to deal with the 8 lug wheels.
I have a similar 1972 f250 (w/390) and it is a lot of fun to drive, not like anything modern.
I agree, add a good brake controller, and away you go, with pretty much anything you can imagine behind it. As long as you can afford to keep the Lima fed..... With a trailer on the back, I am sure you wouldn't have to take your shoes off to calculate mileage, even if you were the victim of a tragic table saw accident....
I had a 75 F250 supercab that started life as a 390 camper special. The truck had 13,000 miles on it and was traded at the local Ford dealer. The previous owner had problems with the timing slipping . My dad bought and drove it to Fla and had problems there. I flew down to drive them home as dad had gotten sick there. I adjusted the timing and off we went. Got back home and did a valve job and changed the intake. Truck kept showing the same symptoms. It ran but dad didn't get to drive it all that long as he passed away. I got the truck and promptly yanked the 390 and installed a 460 in it using all factory parts. I ran that truck for 10 yrs until it rotted away. It got 14 mph loaded or empty would cruse at 70 all day long. I finally did find the problem with the 390, it seamed the timing chain was defective right from the factory. Took a boat mechanic to find it. long story short, you could put the 460 in the earlier chassis and make it look stock.
