FE Power Forums => FE Technical Forum => Topic started by: wayne on August 13, 2019, 01:54:57 PM
How are big f med riser heads differant from small f ones.
Blair Patrick once related that the big F heads had a bigger 164 cc intake port as compared to the small f heads which were 153 cc. He also said you can't port a small f to a big F size without hitting water. Different intake port core.
The combustion chambers are different as well.
