FE Power Forums => FE Technical Forum => Topic started by: Jim Comet on June 24, 2019, 09:04:13 PM
How do you all feel about me attaching my engine torque limit strap to this hole on my aluminum heads. Is there any concern about cracking the bolt hole? should I build a bracket that attaches to both the bolt holes on the front of the head and attach my limiter to that? The car has a 5500 converter and will launch on slicks so it may be tested. I love not having shock towers. I just installed the passenger side header in 20 minutes and the drivers should take about the same. Jim
Yes, make a bracket that uses both bolts. Use Heim joints on either end. Never has hurt my junk.
I agree with Blair
Ricky.
Nearly same setup in some iron heads, been running that way for years without problems. Heim ends make it nicer, mine are build from 3/8 all thread with a hardware store aluminum screen door adjuster and some lock nuts.
I use the same bolt hole for over 20 years on my aluminum heads
I used this hole also for 20 years on my Edelbrock Heads although my strap is bushed at the bottom (leaf spring bush). Can be seen in this pic.
(https://i.postimg.cc/Gp5hj42H/IMG_20171112_160150.jpg) (https://postimg.cc/Lqjp96jp)
