FE Power Forums => Non-FE Discussion Forum => Topic started by: winr1 on June 22, 2019, 07:21:16 PM
Title: I seek an OBII scanner that will bleed ABS and clear codes and lights
Post by: winr1 on June 22, 2019, 07:21:16 PM
Have a 2001 V6 with 70,000 miles, 2009 F150
My old scanner does not see the ABS
Ricky.
Title: Re: I seek an OBII scanner that will bleed ABS and clear codes and lights
Post by: jmlay on June 22, 2019, 08:39:27 PM
Hardware and software that may access the CAN bus will be required. I believe software below has the ability just need a compatible dongle. I have a Chinese knockoff of the elm327 but have not tried it yet.
https://forscan.org/home.html
Post by: winr1 on June 22, 2019, 09:12:25 PM
Thanks JM  :-)
Am eyeing this tool
https://www.amazon.com/Autel-MaxiCheck-Pro-Diagnostic-Service/dp/B075ZLVXHY/ref=cm_cr_arp_d_product_top?ie=UTF8
Ricky.
Post by: TimeWarpF100 on June 24, 2019, 12:02:42 PM
Thanks JM  :-)
Am eyeing this tool
Ricky.
That tool may be able to read a ABS code but not run a bleed brakes. I use the software from Motorcraft the same as dealers have then I can do so much more. Have had it since 2012. One can do anything the dealer can.
Post by: winr1 on June 24, 2019, 09:53:53 PM
Thanks you TW :-)
I'm thinking I will need some kind of dongle to connect a laptop or perhaps an eyepad ??
Also, I have had no luck finding the MS software
Ricky.
