FE Power Forums => FE Technical Forum => Topic started by: 427LX on June 20, 2019, 10:38:15 AM
Title: Tasca Ford KR-8 Mustang.....
Post by: 427LX on June 20, 2019, 10:38:15 AM
Picture here of the supposed Loyd Ruby Ford GT-40 427 Tunnel Port engine that Ford swapped into Tasca's KR-8 1967 Mustang. Looks like those Ford only center squirt Holley carbs.
Story goes that Ford wanted to inspect Tasca's "improved" 428 and ol' Bob said he needed an engine to drive it back home with!
Bet that was a wild drive back!
(https://i.imgur.com/8FJKle7.jpg?1)
Title: Re: Tasca Ford KR-8 Mustang.....
Post by: falcongeorge on June 20, 2019, 10:59:10 AM
That's SO bitchin! 8) Tom, after we were at your place a couple weeks ago, I told the story about the first time I met you back about 30 years ago, and you pulling those tunnel port heads out from under your workbench, and me sh*tting a brick. She just rolled her eyes, and gave me the "so what" look. ::) Wimmen! ;D
Post by: 427LX on June 20, 2019, 11:36:51 AM
Must be another Mr.427...my name Larry but do have a brother Tom although he is a 426 Hemi man and of course still owns his '70 Hemi cuda!
But that's OK falcongeorge!  :)
Post by: falcongeorge on June 20, 2019, 11:51:37 AM
sorry, I wasn't very clear, that was actually directed at TomP. I posted the "bitchin" comment first, then went in and added that comment later, it wasn't very clear, sorry for the confusion.
Post by: gt350hr on June 20, 2019, 01:02:19 PM
   Larry,
      You are correct about the prototype Holley carbs. Those ( done by the late Harold Droste) feature his first version of the not yet made center squirter carb. The unique "bracket" for the air cleaner stud indicates that. Hand made and somewhat crude , they were replaced by the "bar" version that was refined a bit more and was used on "production" 660 center squirters when they were released to the public at a later date. The aluminum Tunnel Port heads are also very apparent.
   Randy
Post by: 427LX on June 20, 2019, 01:23:06 PM
No problem! :)
Post by: e philpott on June 20, 2019, 01:52:13 PM
Look at that big Positive cable on the starter solenoid . Ford should have made about 100 Tunnel port Mustangs to make legal in NHRA Stock
Post by: TomP on June 20, 2019, 02:00:40 PM
Those carbs are cool, would they be an SK# or did Holley not do that?
Looks like aluminum water pump too.
Those were my Tunnel Ports George refers to, I had two sets.
Post by: cammerfe on June 20, 2019, 06:53:24 PM
Harold Droste referred to those center squirters as '652s'. The set I got from Triple E had been used on a GT 40 that was a test car before the LeMans race. Got the entire Tunnel Port upper end and put it on Brother Lon's '67 427 car. It was great fun to take it out to Telway on the South west corner of Telegraph and Grand River.
Post by: gt350hr on June 21, 2019, 09:38:52 AM
   Harold made them in 850,720,652,600,and 440 cfm . "His" carbs all carry signature like modifications and serial numbers.  I have and have had many of his designs. Harold also did many of the "new" designs like the 428CJ carb and most all of the others.
   Yes prototype carbs he made for Ford (EEE) would "usually" have an SK number tag on them but he also did work for the Autolite division where XF numbers were used. I have a few of them also.
    Randy
Post by: 427LX on June 21, 2019, 02:30:36 PM
    Randy
I have seen the specs on the 652 CFM carbs and they list venturi size as 1 5/16 X 1/3/8 and I assume 1 11/16 throttle plate.
The Holley 4224 660 CFM carbs had same venture as the 600 carbs with the larger 1 11/16 throttle plate.
Was it a larger booster design that cut CFM to 652?
Post by: gt350hr on June 21, 2019, 05:06:34 PM
     Harold made them out of the 2804/2805 carb.  He also did them off of the 3255 and 3557 and 1849 and some obscure others. He was a brilliant carb guy.
    Randy
Post by: 67428GT500 on June 21, 2019, 08:50:33 PM
That has the large cable because it's a trunk mounted battery.
Post by: 427Fastback on June 21, 2019, 10:40:47 PM
I see a vacuum can under the right side hood hinge.Typical 67 location for tilt away steering.I also see a hood with the braces cut up and sound deadener on the underside..Sound deadener on the hood is not a Mustang thing....
Post by: 67428GT500 on June 22, 2019, 07:46:16 AM
Well, that or AC on the canister. The deadner started in '69.  The tunnel port was easy to see because of the uprights for the intake manifold bolts.
I would love to have driven that one.
Post by: 427Fastback on June 22, 2019, 12:10:00 PM
No A/C on that car.Plug for the hoses hasn't been punched out of the rad cradle...Maybe the Grande got hood insulation in 69.I have a 69 SCJ here that doesn't have it....Non the less....Very cool car
Post by: cjshaker on June 25, 2019, 12:18:46 AM
No AC on that car, and no deadener in '69, not even on the Grande or 6 cylinder cars. The hoods center depression to clear the air cleaners would have made it difficult to even use. Pretty sure the first year that got deadener was in '74, with the Mustang II.
Post by: Falcon67 on June 25, 2019, 10:41:24 AM
Which makes me wonder why Ford didn't move the solenoid back to the trunk.  Somewhat less voltage drop and no hot cable running the full length of the car.
Post by: C8OZ on June 25, 2019, 10:50:58 AM
I've wondered. I suspect the total weight of adequate starter cable PLUS the additional charging, dash feed, etc. eventually outweighs the gain.
The Boss 429 cars kept this same setup into 70, too.
Post by: 427LX on June 25, 2019, 01:58:56 PM
Was there any throttle progression on those carbs or 8 bbls. opening all the time when cruising?
With a center squirtter even some progression would have accel shot fuel puddling on closed secondary plates which wouldn't be to great for clean running at part throttle.
Post by: gt350hr on June 26, 2019, 10:55:33 AM
427LX
      The linkage in the KR8 picture on the first page of this thread is not progressive. Yes the cam operated secondaries were were progressive. There was a problem initially with fuel puddling on the secondary butterflies but the ever creative Holley engineer Harold Droste drilled a passage in the base plate( above the "closed" butterflies) that allowed the fuel buildup to "dump" into the primary side. Being above the butterflies it eliminated an air leak when the butterflies were closed and had no effect when they were open. I have several of these prototype carbs that are done that way.
    Randy
Post by: falcongeorge on June 26, 2019, 01:23:17 PM
427LX
    Randy
That's a really cool idea that could be transferred over to the 660's. Randy, would it be possible to post a pic of one of those baseplates?
Post by: gt350hr on June 26, 2019, 03:56:53 PM
   I am photo challenged and not "smart" enough to own a smart phone , no kids either. It is 3/16ths and was done with a long shank drill from the secondary side toward the primary side so there is a slight down angle. Try a piece of brake tubing and you will be able to see how it was done. I thought about making an angle plate for my drill press as some of min do not have this later revision. "I" feel since I can't ask Harold (rip) it also held create a slight pull on the boosters to eliminate any potential bog as the squirt shot would be less than that of a "double pumper."
    Maybe Drew can post a picture as he has some too.
     Randy
Post by: falcongeorge on June 26, 2019, 05:27:37 PM
     Randy
Thanks Randy, I'll take a look at one of my 660's and figure out how to add it. I assume it exits below the throttle plates on the primary side? It would circumvent any need to drill an idle air bypass in primary side throttle plates too. And I think you mean you ARE smart enough NOT to own a "smart" phone.  ;)
Post by: gt350hr on June 27, 2019, 09:42:27 AM
     The "passage" is ABOVE the plates on both sides . Otherwise you would idle way too high. It only comes into play when the throttle is "cracked" a bit past idle and up to the point the "cam" begins to open the secondaries. That is when the center squirter is dumping fuel onto the closed secondary plates at the same time it is spraying the primary. The later double pumper eliminated all that .
Post by: falcongeorge on June 27, 2019, 01:41:42 PM
 if you drilled it so it exited below the primary throttle plates the idle would probably be on the high side(depending on valve timing) if you made it 3/16, but if you made it smaller like 3/32, and didn't drill idle air bypass holes in the primary side throttle plates, you could kill two birds with one stone, it could take the place of the idle air bypass holes that you usually need (with a bigger cam) to keep the throttle plates down out of the transfer slots at idle, and also bypass the fuel that commonly collects on the secondary throttle plates at part throttle with center squirters. That's my thinking anyway.
Post by: 427LX on June 27, 2019, 02:44:43 PM
gt350hr...thanks for that info on those carbs! I don't think anything was mentioned about these carbs in any of the magazines or Ford Racing info back in the 67-68 time frame.
On my custom setup using the Holley 660 4224 carb on a dual quad setup... I run a 650 CFM carb with vac. secondary as
the primary cruising  carb and at 40% throttle travel the linkage starts to open the rear 660.
The front carb's Vac. Secondary with white spring then opens up about same time the 660 is full open.
Works extremely well in my 3000 lb. 1985 Mustang LX with the 427 Windsor.
Must mention that the 660 was recalibrated to same fuel curve as the 650 and uses a power valve.
(https://i.imgur.com/HftBXUe.jpg?1)
Post by: gt350hr on June 28, 2019, 10:05:53 AM
  I am familiar with your build and enjoy what you've done. I was considering following your lead and going that way on my '67 Ranchero 408W but have since built a dual quad 521 ( 460 style) for it. Have yet to install it. More weight and bulk but 600 easy , trouble free HP. I'm using original BC/BD carbs with vacuum secondaries.
    Randy
Post by: 427LX on June 28, 2019, 07:56:01 PM
Now that sounds like a cool build? Blue Thunder intake by any chance?
Post by: gt350hr on July 01, 2019, 10:58:04 AM
   Yes. The small one with the upper portion of the port matched to the early aluminum CJ heads.
Post by: rockhouse66 on July 01, 2019, 06:46:59 PM
I can't speak to '68, but Grande's and Mach 1's (w/o ram air) got the under hood insulation in 1969.
