FE Power Forums => Non-FE Discussion Forum => Topic started by: Stangman on June 08, 2019, 06:03:36 PM
Title: Tranny up shift 2-3
Post by: Stangman on June 08, 2019, 06:03:36 PM
So took car out for the first time after surgery. Wasn’t running that great till it ran for a little while, took it for a ride adjusted carb and all was good. Took it for a couple of short rides all good. Just got back from a pretty good ride maybe 20 miles. Got home readjusted carb running mint, shut it off and one of the kids wanted to go for a ride. Start it up take off and all of a sudden it doesn’t want to shift automatically into 3rd. It’s a TCI tranny and it’s my second one that I’ve had and both of them shift 1-2 within 20 feet and into third about 50 -75 feet. Now it’s shifting into second at 75 feet and doesn’t shift into 3rd. Now I just put a new manifold on and ran a new modulator hose, which I’m pretty sure I couldn’t have burnt  a hole in it but will check of course but that would kill my back. Tranny cooler was nice and cool after the ride and it’s 80 degrees and a little humid. Could the modulator have taken a dump. This tranny only has maybe 1000 miles on it.
Title: Re: Tranny up shift 2-3
Post by: Stangman on June 08, 2019, 06:30:46 PM
Ok got yelled at by the wife but got under there and found modulator line off. Couldn’t get it on but tomorrow I will. Boy I don’t know about anyone else but I go right to the worst when something goes wrong all of a sudden.
Post by: Heo on June 08, 2019, 07:12:07 PM
I thought about that but i thought...Naahh he have checked that ;D
Post by: Drew Pojedinec on June 08, 2019, 07:51:06 PM
I have a 24 hour rule on posting a problem.
I require a nights sleep and to dig back into it before I ask the masses :P
Post by: Stangman on June 08, 2019, 08:02:07 PM
Yeah I hear ya didn’t want to ask so fast but remember I just had surgery and I just wanted to run it by you guys. I can’t do much and figured it was the vacuum or modulator or a piece of dirt in the governor. I’m glad it was this. Thanks for answering.
Post by: Drew Pojedinec on June 08, 2019, 08:22:45 PM
I'm no transmission expert, but I don't think the gov has much to say about this low speed shifting.  Sticky governors in a c6 always left me in third gear at a stop sign.  Don't think I've ever had the higher speed weight being much an issue.
Post by: Stangman on June 08, 2019, 10:27:03 PM
How about my last tranny, at the end of a pass at the track almost as soon as you got off the gas it would downshift into second. I took off in second gear and overheated the tranny and it started right after that.
Post by: FirstEliminator on June 11, 2019, 07:04:04 AM
  Sounds like vacuum modulator hooked up to ported vacuum for that symptom.
