FE Power Forums => Vendor Classifieds => Topic started by: blykins on May 22, 2019, 12:39:48 PM
Title: Lykins Motorsports non-adjustable roller rockers in stock, 9.26.20
Post by: blykins on May 22, 2019, 12:39:48 PM
Another shipment coming in Monday.
Title: Re: More Lykins Motorsports non-adjustable roller rockers are on the way....
Post by: 67428GT500 on May 22, 2019, 12:53:34 PM
Donating parts?  8)
Post by: blykins on May 22, 2019, 02:34:31 PM
Yep, $450 and I'll donate a set to any cause.
Hey, pay $900 for one set and I'll even throw a set in for free.
Post by: 67428GT500 on May 22, 2019, 02:36:00 PM
I have dove rollers, but if I break one I will definitely be coming to you.
Post by: shady on May 22, 2019, 03:26:27 PM
My motto is charge double and give 50% off.  They are pretty, I just couldn't resist taking a peek at them.
Post by: blykins on July 25, 2019, 05:55:22 AM
Rockers are here.  Get 'em while they're hot.
I can also package these up with HS shafts and POP stands.
Post by: My427stang on July 25, 2019, 06:48:21 AM
Brent, I need a third set, keep them coming!
FYI - If any of you are on the fence, what an easy decision during a build.  I was going to do a write up, but what kind of write up can you do when you just bolt them on, check pushrod length, buy cheaper pushrods because they are common size, gain pushrod clearance, etc?  They are just easy and nice.
Also FYI - They fit at .630 lift under PBF valve covers if you squeeze the baffles a little with a pair of channel locks...easy job, at more normal lift, I'd expect no issues at all, and tons of room with pentroofs, both cast alum and steel
I guess that was a write-up   :o
Post by: Arizona ‘58Mercury on August 10, 2019, 08:06:27 PM
So what’s it run for the whole set up?  Rockers, shafts and pop ups
Post by: blykins on August 11, 2019, 11:52:44 AM
Pop ups?  You mean stands?
Post by: Arizona ‘58Mercury on August 14, 2019, 01:03:29 PM
Yes, I miss read what you put above.
Post by: blykins on August 14, 2019, 01:09:35 PM
Complete kit for a LR/MR combination would be $910, including rockers, HD shafts, billet end stands, billet center stands, and billet spacers.
Post by: Arizona ‘58Mercury on August 14, 2019, 01:42:01 PM
I got my cam and lifters through you, I’ll be in touch on these as well.  Thank you
Post by: e philpott on August 14, 2019, 03:58:09 PM
Sweet deal Brent !!
Post by: Sand hauler on August 20, 2019, 08:31:13 PM
Can I use the PAC 1940 springs with these,or would I need to use a smaller dia spring?
Post by: blykins on August 21, 2019, 04:38:36 AM
They will clear/fit just fine.
Post by: Sand hauler on August 21, 2019, 05:55:12 AM
Thank you sir,will definitely be ordering some :)
Post by: blykins on August 21, 2019, 06:18:27 AM
2 sets left on the shelf....
Post by: Arizona ‘58Mercury on January 04, 2020, 05:49:16 PM
How are these performing?  Any feedback on them?
Post by: My427stang on January 04, 2020, 06:43:35 PM
I have used three sets, couldn't be easier and no issues at all.
Going to buy at least one more set in the next month or so.
Title: Re: Lykins Motorsports non-adjustable roller rockers in stock, 1.23.20
Post by: blykins on January 23, 2020, 05:28:26 PM
Shipment is here.
Post by: My427stang on January 23, 2020, 05:34:36 PM
I need another set!
Post by: drdano on January 23, 2020, 05:46:40 PM
Get in line!   ;D ;)
Post by: My427stang on January 23, 2020, 07:13:54 PM
Get in line!   ;D ;)
I think I have the most frequent flier miles :)
Title: Re: Lykins Motorsports non-adjustable roller rockers in stock, 5.11.20
Post by: blykins on May 11, 2020, 01:49:46 PM
Rockers in stock!
Post by: DubyaTF on July 06, 2020, 10:39:07 AM
    Any sets of rockers left? I sent a PM with a couple questions. Thanks for your time!
Post by: blykins on July 06, 2020, 11:03:21 AM
Shot you a PM back.
Post by: DubyaTF on July 14, 2020, 01:54:30 PM
  Received my rocker set last night. Everything looks good. Thanks very much!
