FE Power Forums => Private Classifieds => Topic started by: babybolt on November 20, 2012, 08:56:46 AM
Two FE blocks available for delivery to Columbus, one is a D2TE or D3TE with the 3 web mains, standard bore $225, and the other is a 63 or 64 block with the extra knorbs inside the pan rail for the crossbolts. Date code is either 3C18 or 3G18, no other casting id's other than DIF. Standard bore, $400.
Doug, what is the bore size? Are these 390 blocks?
Yes, 390 blocks, 4.05 bore. I looked at the truck block this morning, it is a D4TE.
