FE Power Forums => Non-FE Discussion Forum => Topic started by: winr1 on April 07, 2019, 09:35:16 PM
Rebuilt a Holley 600 Va. secondary for my 352, runs nice now
Used a Quick Fuel rebuild kit, had the black bowl bolt washers, the diameter is small but squish out
Had to tighten the front bowl bolts more than the rear bowl bolts
The placement hole on the front bowls are larger than the placement holes on the rear bowl
You can see the washers on the rear bowl after tightening
The front washers squish to where the built in bolt washer touches the bowl
Gonna get some regular washers but was wonderin want yall use ??
Also, on the carb, I did not notice till the mill was running
There is no ported vacuum on the metering plate ??
I need this for my vac. advance on my distributor
Any way to fix this versus getting another metering plate ??
Ricky.
I always use Holley kits. Have heard stories of problems with using other people kits. Nothing horrible, but like yours, the stuff is not quite "right".
I've started using the black plastic washers for fuel bowl. Holley gives them with every kit now. Much more reusable compared to the paper gaskets from years back. Never had a leak or issue with them.
As for ported vacuum? How about drilling a hole and installing a pipe fitting? Or can you buy the correct plate? I'll dig through my pile of 600 stuff and see if I have another plate with a port fitting. It's yours if you need it.
on my 600s, the vacuum port is right under the front of the sec. vacuum diaphragm. if the brass nipple is missing, easy to miss or maybe it is plugged.
I've had problems with the black plastic washers leaking. Chased a stubborn weeping that I thought was the accelerator pump cover. After resurfacing both cover and bowl it still weeped, not alot, just enough to dampen the bottom part of the bowl with an occasional drip. Pulled the bowl, mounted in the mill and using a 4 flute end mill spot faced the bowl screw surface and found it took about a .009-.010" cut to true up the mating surface. The old paper gaskets would conform to just about any surface for a fuel tight seal...The plastic washers? Not so much. I now spot face all bowl screw surfaces as SOP when I build a Holley.
Interesting. I can see it happening though(and at first was skeptical). Guess I've been real lucky up to this point? Or the fact that all my carbs are over 20 yrs old, they were machined better back then?
Thanks much guys !!
I will look at the Holley again and see what I can see
Ricky.
Or maybe lived a charmed life? I've found the problem on both old and newer [less that 10 y.o.] I've used other plastic washers, mainly white ones from a hardware store. A little thicker but a 'reusable' type. I haven't had any problems until using the Holley black washers. Maybe they are a lot harder and don't conform as easily.
Same. I had to pick up an Edelbrock kit for a 4160 at Pep Boys because I needed pump diaphragms and that's all they carry. It was at least decent and got me by for a bit.
The pics are of the carb I need a vacuum cover for ....
Any have a vacuum secondary cover ??
Also, Tommy or anyone that has a front jet plate with a ported vacuum tube on it
And.. any ever see a holley with just the aluminum rear plate, no thin plate in between ??
The 600 Holley I was rebuilding earlier has only the aluminum plate ??
(https://i.postimg.cc/x1BKzYfD/IMG-5772.jpg) (https://postimages.org/)
(https://i.postimg.cc/4xHcZMz8/IMG-5775.jpg) (https://postimages.org/)
(https://i.postimg.cc/zvfLQPzF/IMG-5777.jpg) (https://postimages.org/)
Secondary sealing plate for use on model 4160 carburetors that have a power valve cavity on the secondary side.
https://www.holley.com/products/gaskets/carburetor_gaskets/parts/108-122?gclid=EAIaIQobChMIqefny9XJ4QIVxrrACh2PMA5ZEAQYAiABEgIDjvD_BwE
Ricky.
I guess I am getting old - I actually prefer the paper washers. They seal well and have a little give to them and don't put all the clamp load against the bowl and block gaskets.
I had one of those really inexpensive Holleys come in on a customer project. It had no sealing gasket or thin metal plate behind the die cast secondary metering plate. I decided that was doomed to fail in service from eventual gasket deformation, found a plate & such from my stash, installed them, and continued on.
.Holleys that I have had that didn't use the thin metal plate didn't have a power valve cavity.
Not that I go through my carbs very often, but nice not to have to keep buying those little paper gaskets for fuel bowls. I was skeptical of the plastic rings, but all my hot rods have them without issue(everything I own has 2x4's on it).
I'll poke around in my Holley junk box this weekend and see what I have extra. Should have something.
Thanks guys !!
I found some fiber washers at ace, a bit thicker than Holley paper washers
They fit the bolt well and the bowl relief as well
I have a good metering plate and a center hung bowl if anyone can use them
Ricky.
Something like these:
(https://i.postimg.cc/Sx1KYhw9/IMG-20190414-204205502.jpg)
(https://i.postimg.cc/9QkWFB7t/IMG-20190414-204224423.jpg)
Those look what I need
I noticed the vacuum port, all the 4160 carbs I have seen had a pressed in tube
The plate I have has a large large hole where the tube would be pressed in
Perhaps 2 different castings ??
The one with the large hole may be drilled into ported vacuum and the hole threaded from factory ??
Are they spares ya do not need ??
I would gladly pay ya or trade for them... 427 block, stack of hundreds, milk an whiskey .....
Ricky.
I think I had the pressed in version but it is ugly. This one was clean. I think I had a large hole that was not tapped also.
This stuff is all extra. Yours for the taking. Give me an address and I'll get them coming your way.
There are a different front blocks for 600s IMHO. Some have the pressed in pot, others threaded. As there are a bunch of "600" vacuum secondary Holleys in various List numbers.
I only use the nylon washers and haven't had a single issue with them. I personally like the blue ones but will make due with the white ones.
This block is 8485. I'll check the others I have.
PM sent an thanks !!
Where do yall purchase seperate washers ?? .... I only found the ones that came in the QF kit
Thanks much for all the replys guys !!
Ricky.
I purchase the old style paper bowl screws 250 at a time, they aren't terribly expensive that way. Same with the old style fuel inlet seals. If you needed just a few I'd be happy to help. Same with VS lids, etc.
The reusable nylon stuff seems to work well on newer carbs but many times they make for a weep on the older stuff.
If the metering block doesn't have a ported vac spot, you can drill a feed hole in the metering block face. 1/4-28 is the size to tap to for standard fittings. I would make sure you are using a primary block however before doing that. Not the end of the world, but using a secondary block with a raised angle channel can cause some issues on the primary side.
Having been messing with carbs for 45 years, I just have a good pile of parts left over from various kits. I'll buy a $40 kit just for a fresh gasket and a couple of seats assemblies. It's a wash on cost, or cheaper. A single 110 Viton needle and seat $18.49 at the Advance Auto around the corner from work. So that's $36.98 for both ends. The whole renew kit for a 4150 DP carb is $38.40 my cost at the Summit Pro Shop.
Thanks much ... again guys !!
Ricky.
