FE Power Forums => FE Technical Forum => Topic started by: BBFORDFAN on February 09, 2019, 08:44:01 PM
Title: Sbf roller lifters in an FE?
Post by: BBFORDFAN on February 09, 2019, 08:44:01 PM
Can sbf roller lifters be used on a roller cam in an fe? I've heard you can. What needs to be done? Thanks in advance jim
Title: Re: Sbf roller lifters in an FE?
Post by: blykins on February 10, 2019, 05:44:56 AM
No sir, won't work.
Most of the time on Ford roller lifters, the diameters and heights are the same between Ford engines, but the link bar lengths are different, because the lifter bore spacing is different.
Post by: BBFORDFAN on February 10, 2019, 09:04:34 AM
Thanks you!!
