FE Power Forums => Non-FE Discussion Forum => Topic started by: chris401 on December 11, 2018, 11:35:12 AM
Time has come for a new door. I can make one out of plexiglass or have some real glass cut with some kind of stick on protector.
Question: What have you done that has worked out better for your cabinet?
This is how I fixed mine - that little box is way to small to be that useful. Sold it for $20
(http://raceabilene.com/misc/NewShop/BlastCabinet.jpg)
That looks like one of the smaller cabinets I used at work. Once you get used to using a blast cabinet you'll find the small one I have is quite useful. Although awkward and time consuming I can do a valve cover in mine. Intakes and larger pieces I use a hand held blaster.
Glass or plexi, buy some clear 'shelf liner' at any store selling home/kitchen goods. It's a plastic on a roll, with a tear-off liner, that reveals the self-stick backing. Cheap, lasts a long time, easy to tear off and replace with another sheet.
We have a similar model at work, and you can order stick on covers for the inside to help with it getting etched and you can't see through.
https://www.tptools.com/HOBBY-PRO-HP-50-Cabinet-Inner-Lens-Protectors-3-Pk,8275.html?b=d*23502
Though the shelf liner might be cheaper and do the same thing.
