FE Power Forums => FE Technical Forum => Topic started by: Tor on November 26, 2018, 07:26:21 PM
Hello
Do you see any problem about removing the fuel log an put it back on again on a 67GT500. Will it be a problem fore the gasket sealing fore the manifold? I have to replate the finish on the fuel log.
Tor
You are thinking about the bolts you have to remove?
No i dont think you are getting a problem with the
gasket seal after that
I don’t see a problem with that. If you don’t feel right about it retorque after you take the log off. And then take back off after you have it plated ;)
My thought was to remove the fuel log and tight up up the bolts. When the fuel log is platet I have to remount it again.
Tor
