FE Power Forums => FE Technical Forum => Topic started by: GJCAT427 on November 23, 2018, 03:55:12 PM
Title: Cam bearing usage on 427 marine block.
Post by: GJCAT427 on November 23, 2018, 03:55:12 PM
The block I got last summer is a marine block not drilled side oiler core. Which cam bearings would be correct for it? Std 390 hydro or 427 side oilers. When I got it the block had been tanked and oiled. Getting ready for assy and running a factory solid lifter cam. Barry, Brent or Blair?
Title: Re: Cam bearing usage on 427 marine block.
Post by: blykins on November 23, 2018, 05:32:47 PM
Are the cam bearing bores in the block grooved?
Post by: CaptCobrajet on November 23, 2018, 05:48:56 PM
F33 Durabond.
Post by: GJCAT427 on November 23, 2018, 06:33:19 PM
Brent, yes the bores are grooved. Lifters were solids and the oil passages are not drilled. Blair I`ve been trying to get in touch with you, but the phone says message box is full. Garry
Post by: blykins on November 23, 2018, 06:42:59 PM
I was just making sure, but Blair beat me to it.
Post by: GJCAT427 on November 23, 2018, 06:50:14 PM
Thanks guys Garry
