FE Power Forums => FE Technical Forum => Topic started by: ToddK on November 13, 2018, 04:43:02 AM
Title: CVR water pump leak
Post by: ToddK on November 13, 2018, 04:43:02 AM
I have the CVR extreme water on one of Jay’s water pump adapters, and the pump has developed a leak. You can see the red coolant leaking out in the picture below.
(https://i.postimg.cc/HWXhxKC7/3-BB64-EFC-7-F2-A-486-A-B25-C-11-A113567-C3-F.jpg) (https://postimg.cc/WtpnY5z2)
I’ve tightened the four screws at the front of the pump, but don’t want to tighten them any more in case I strip the threads. Has anyone had a similar problem, and can the pumps be pulled apart and repaired?
Title: Re: CVR water pump leak
Post by: mbrunson427 on November 13, 2018, 08:56:18 AM
Well, I had a different thing happen to mine. But when they sent the replacement, the replacement leaked at the spot yours is leaking. I took it apart and put some ford grey sealant on that gasket surface very lightly.
Jay posted a picture in my old thread showing the pump apart. Might help you out.
http://fepower.net/simplemachinesforum/index.php?topic=5076.0
Post by: ToddK on November 13, 2018, 05:24:50 PM
Hey Mike, thanks for that link, it’s just what I needed. I think mine is leaking from the gasket between the front assembly and the rear section. I might get hold of the repair kit assembly and see if it fixes my leak. Thanks again.
